Pd-170 - risks in the LCD screen, or white lines appear on the LCD, error
Hello my pd-170, presented at the end of last week, risks in the LCD screen, or white lines appear on the LCD and then the screen goes all white, then when I close the LCD open and again the image is then begins to emerge and so the risk goes up. Friends of the forum, vcs ja had this defect in a camera to have, I would like to know any story. How am I doing a search, the camera is already in the technical, and he confirmed that the lcd ta perfect and is now looking for a component that can give it this small defect in the lcd ... As this forum is incredible, maybe someone has already gone through this defect, or has a friend who can tell us how to solve this defect, as a way to exchange information.
denis |
friends
friends understood the questions you
Denis,
I hate to say it but honestly I really don't understand the question completely. What I get from what you are saying is that the LCD turns white the disappears completely. IF that's what is happening, what happens to the veiwfinder? Does it do the same thing? About the only thing that I would try if it happened to me would be to try the RESET button located on the panel where the menu and other buttons are. If the RESET button doesn't fix it then your only option is to take it in somewhere to be fixed by a certified Sony technician. |
My lcd with the white lines in place of the images, I'm from Brazil and I'm using google to translate.
denis |
This sounds as if the flexible circuit (ribbon cable) that connects the LCD to the Camera circuit board may be faulty. Or the connector.
It may be that the contacts are dirty and removing and inserting the flexible circuit (ribbon cable) may clean it enough. |
Hello mike this tip to their technique has already made, without success, I await other tips
| All times are GMT -6. The time now is 10:48 PM. |
