DV versus DVCAM Transitions
On P. 19 of the PD-170 Operating Instructions in the "Notes" section under the heading "Usable Cassettes," it says, "If you record in the DV format, the transition of a tape may not be smooth. We recommend that you use mini DVCAM cassettes and set REC MODE to DVCAM in the menu settings to obtain reliable clear pictures."
Is this really an issue or just an effort to sell the DVCAM format and the cassettes it uses? |
Re tapes, high grade MiniDV tapes are perfectly okay for DVCAM. |
DVCam was designed for the broadcast world back when they didn't use non-linear editing systems, they used linear editing systems with their constant back and forth tape motion. Hence they needed rugged tape and cassettes because the broadcast folks heavily reuse their tape. If you drop a DVCam cassette, it is more likely to survive the abuse than if you drop a DV cassette.
The signal recorded in DV and DVCam is identical. The only difference is the DVCam 1's and 0's each are written to a wider magnetic spot in the tape because the tape is moving faster in DVCam. At NAB, I got a Sony tech rep to agree that there is no quality difference between the two tape formats. And it really isn't a format difference, just the physical space taken by each 1 & 0. For normal, single-pass use, the cheapest Sony tape is more than good enough. I've bought thousands of them from distributors and never had a bad tape or a tape-related recording failure. |
The only difference between DV and DVCam is tape speed. DVCam runs at twice the speed of DV. Data rate and compression is the same.
DVCam with the higher tape speed has a higher signal to noise ratio. This helps prevent dropouts. Good tape is so good these days that dropouts don't happen often. I would run DV mode using good tapes and not worry about running DVCam. |
As I understand it, the DVCAM magnetic tracks are the same width as those of DV, but have a wider buffer area between them. Also, since the tape is moving faster, the helical tracks would have more curve to them and their required length would fit on a narrower width of the tape, leaving more free area along the margins. Note: DVCAM rolls the tape 50% faster than SP-mode DV.
Getting back to Robert's original question.... I always thought that this warning in the manual referred to mixing both DV and DVCAM recordings on the same tape. In other words, if you do that you will get a bit of a glitch in the transition between a DVCAM and DV recorded section of the tape.
I love Sony products, but their manuals are just awful... |
| All times are GMT -6. The time now is 02:25 PM. |
