-   Sony TRV950 / PDX10 Companion (https://www.dvinfo.net/forum/sony-trv950-pdx10-companion/)
-   -   Raynox wide angle (https://www.dvinfo.net/forum/sony-trv950-pdx10-companion/47438-raynox-wide-angle.html)
Lucius Snow July 9th, 2005 05:46 AM
Raynox wide angle
Hello all,
I own a Raynox HD5000 Pro 0,5 wide angle that i fit on my TRV-950. I'm pretty happy with it (the deformation is visible but still acceptable) but i get lots of artifacts due to the sun light. I'd not be able to describe them in english so let me show you a screenshot :
http://poubellelqt.free.fr/bordel/Image0.jpg
The image is interlaced but it doesn't matter, you get what i mean. There are two noticeable effects there.
How could i get rid of that ? I think i can't hook any filter on the Raynox HD5000. I'm ready to buy a new wide angle even with an extra accessory if necessary. What would you advice me to buy ? I need a 0,5x high quality wide angle on a 37 mm ring, just like that Raynox, but with the possibility to avoid these artifacts. My budget is $150-200 max.
Thank you.
Cheers.
Chris Thiele July 9th, 2005 03:43 PM
Hello Lucius Snow,
Did you photgraph this through the window of a moving vehicle?
1. There looks like quite a lot of camera movement.
2. Looks like reflections off glass.
3. There is lens flare (from the sun)
4. And there is Vertical smear. (Long straight line)
May I suggest that you take another photo with the camera on a tripod (to prevent movement) and take the photo not pointing into the sun. Then it may be easier to start to review and help you.
If you have movement, through glass into sun, all lens' will struggle.
Lucius Snow July 9th, 2005 03:58 PM
It's actually a captured image from a video footage, taken by car, you're right. The glass of the car is down though. I have to film in that way but i'd like to avoid all these rays coming in the lens.
Here is another capture coming from a footage when the videocamera is on the tripod :
http://poubellelqt.free.fr/bordel/Image1.jpg
Thank you.
Lucius Snow July 12th, 2005 08:47 AM
I notice that the Canon WD-58H wide angle has a sunshade included. Is it the same kind of accessory i'd need ?
Look at it this picture :
http://www.digex.com.cn/PRODUCT/cannonsx/wd58h.jpg
Thanks.
Samuel Birkan July 12th, 2005 12:49 PM
I have the Century wide angle for my 950. It has a 62mm front thread. I keep a UV on it permanently and also have a folding rubber lensshade that is not expensive. At wide open I fold it back so it projects about 1cm foreward, and as I zoom in I open it. I also have the Cokin filter system with cokins lenshood. It works at all but the widest zoom.
Lucius Snow July 12th, 2005 12:54 PM
Can you give me the name references of all these accessories ? Thank you.
Samuel Birkan July 13th, 2005 08:35 AM
Here is a link to the lens http://www.bhphotovideo.com/bnh/cont...ughType=search
Here is a link to Cokin http://www.cokin.com/ico4-p1.html.
You would need a 62mm ring, a filter holder and a lenshood. You can look for them at B&H.
The lens hood I use I just bought at a local camera store. here is an example
http://www.ritzcamera.com/webapp/wcs...uctId=13234064
or here
http://www.bhphotovideo.com/bnh/cont...goryNavigation
Lucius Snow July 13th, 2005 02:30 PM
If i understood well, here are the two possibles schemas :
TRV-950 => Century wide angle => 62 mm ring => Filter holder => UV filter
TRV-950 => Century wide angle => Lenshood
But is it possible to do the following one :
TRV-950 => Century wide angle => 62 mm ring => Filter holder => UV filter => Lenshood
I selected that on B&H :
http://www.bhphotovideo.com/bnh/cont...=220297&is=REG
http://www.bhphotovideo.com/bnh/cont...=307120&is=REG
Is it the Cokin system you use ?
Samuel Birkan July 14th, 2005 06:07 AM
All your examples are possible. Mine is a little different. I have the
Century ==> Cokin 62mm ring with filter holder===> Cokin Lens hood.
http://www.bhphotovideo.com/bnh/cont...Type=accessory
Usually though I remove the UV filter when I mount the Cokin system so my second option looks like this
Century===> Screw in 62mm UV Filter ===> Screw in 62mm foldable rubber lenshood.
By the way this is a very usefull filter to add to your setup
Tom Hardwick July 27th, 2005 12:08 AM
To get back to Lucius' original problem - the artifacts you see are caused by non image forming light bouncing around inside the lens elements of your zoom + Raynox, and it's called flare.
The easiest way to avoid this is to shoot with the light behind you, but as this isn't always possible or desirable, the answer has got to be: get a lens hood, and use it.
The lens hood is the cheapest, lightest, simplest accessory you can buy and it brings with it rewards that are out of all proportion to the cost. Your second shot Lucius shows that when light doesn't strike the front element the image quality is fine, and there's no flare.
tom.
Lucius Snow July 27th, 2005 03:52 AM
Thank you all. I'm going to buy these accessories now.
Sean McHenry July 27th, 2005 07:17 AM
I thought I had mentioned this but have you looked at the Cinetactics MatteBlox? It is a soft matte box system that works with almost any lens and has verious shade extensions.
http://www.cinetactics.com/
Sean
Ronald Lee August 1st, 2005 01:14 PM
tom.
Not much selection for lens hoods.... will the large one supplied by the PDX10 work?
