AC adaptor for TRV33
I just bought a used Sony DCR-TRV33, which came with no AC power adaptor or power cord. According to the manual, the TRV33 comes with an AC-L15A/B AC adaptor. Would my PD150's AC adaptor, model # AC-L10A, work with the TRV33? It looks like AC-L10A's plug can fit in the TRV33's DC IN port. How could I find out?
Thank you. |
Does the PD150 use the same battery as the TRV33? If so, you should be able to, just check the specs between the 2 adapters before trying. Make sure all your +, - and gnd are on the same pins and also that the voltage and current are the same. Higher current will kill your camera. |
My guess is the PD150 takes more current. The universal charger you're talking about, may set voltage current and polarity when you connect whichever battery you are trying to charge. Buy the universal one.
Here are the specs of the 2 cameras and their AC power adaptors:
PD150: power requirements 7.2V (battery) 8.4V (AC adaptor) AC-L10A adaptor: power requirements 100-240V AC, 50/60Hz power consumption 23W (31-42VA) output voltage DC OUT: 8.4V, 1.5A TRV33: power requirements 7.2V (battery) 8.4V (AC adaptor) AC-L15A adaptor: power requirements 100-240V AC, 50/60Hz current consumption 0.35-0.18A power consumption 18W output voltage DC OUT: 8.4V, 1.5A Is this information helpful enough to someone who knows about power consumption and can possibly help me figure out whether or not the AC-L10A adaptor would work with the TRV33? Thank you. |
If the pins are the same, then yes. |
Stephen, thank you for your help. When you say "If the pins are the same," do you mean those of the plug of the AC adaptor that connects to the camera's DC IN port?
Lookup the Sony adapters on Bescor.com. Then call them. I use their stuff for my PDX10 and have had no troubles. Make sure you call them about this one.
I believe all Sony cameras that have the small flat connector are all the same voltage input to the camera. Call Bescor. Higher current will not kill the camera. Higher voltage will kill the camera. I can use a 300 Amp power supply but nearly all that power will never be used. The device will only draw the current needed to operate it. Voltage on the other hand will damage the rectifiers and voltage regulators in the initial power supply stages in the camera (or any other device). As proof, the average 2-way radio gets hooked directly to a car battery and has no issues. The radio may only draw 3.5 Amps but the battery capacity may be 400 cold cranking amps. No problems. Sean McHenry |
| All times are GMT -6. The time now is 10:48 PM. |
