-   Sony TRV950 / PDX10 Companion (https://www.dvinfo.net/forum/sony-trv950-pdx10-companion/)
-   -   PDX10 Vs. DV953 (Pan) (https://www.dvinfo.net/forum/sony-trv950-pdx10-companion/15054-pdx10-vs-dv953-pan.html)
Steve Nunez September 27th, 2003 02:10 PM
I really hate the "VS / versus" thing........but after looking at feature-sets of both the Sony PDX10 and Panasonic DV953- it seems they are both direct competitors- down to the 16:9 native recording and poorish low-light performance- which of these 2 cams produce the better (natural colors- and sharp video) image quality?
Hopefully someone here owns both or has tried both and can comment...any words on these 2 direct competitors?
Frank Granovski September 27th, 2003 02:23 PM
I tried the TRV950 and PV-DV953(MX5000). In terms of image quality, the Japanese reviews say the PV-DV953(MX5000) is better. But I do not think you'll see a difference, unless you hook them to a large 400 line TV, side by side.
Steve Nunez September 27th, 2003 02:36 PM
Thanks Frank, the 953 does have a reputation for "sharp" video...but I am more concerned about the PDX10 VS the DV953 as I am planning on getting one of these cameras as soon as B&H comes out of holiday closing....I'd like true 16:9 recording and 530+ lines resolution.....I wasn't too thrilled with the Canon XL1S or GL2's "look" on my Mitsubishi 65" HDTV...I'm hoping for better results from the PDX10 or 953 on that set...maybe I'm asking for too much but i don't recall either of the Canon's as having 530 lines+ res!
Frank Granovski September 27th, 2003 02:41 PM
The MX500 (the PAL version of the MX5000/PV-DV953) was tested to play back 540 lines. I assume with the PDX10's high pixel count, the resolution would be about the same. Read Allan's notes here:
http://www.dvinfo.net/conf/showthrea...threadid=14978
Tommy Haupfear September 28th, 2003 12:06 AM
I traded in a DV953 for a PDX10 and I've been very pleased with the upgrade.
One thing to note on the DV953 is that while the 16:9 mode is lossless for resolution it does not give a wider angle of view like the PDX10.
I also found that the PDX10 handles extreme contrasts noticeably better (trees/skyline).
Both are great cams but I think the PDX10 edges out the DV953 and you even get XLR inputs.
Here are a few frames from each cam. Both are in 16:9 mode with the DV953 frames also being frame mode.
DV953
http://www.villagephotos.com/pubbrow...elected=339297
PDX10
http://www.villagephotos.com/pubbrow...elected=441334
These next couple are digital stills in VGA mode (640x480)
DV953
http://img.villagephotos.com/p/2003-...Picture360.jpg
PDX10
http://img.villagephotos.com/p/2003-...5/pdx10(1).jpg
Frank Granovski September 28th, 2003 12:50 AM
Thanks, Tommy. Also the PDX10 costs a good chunk more.
Tommy Haupfear September 28th, 2003 06:15 AM
Yep, a substantial difference of $800. Thats a lot of accessories!
That and I think the GS100 will put to rest the differences between the DV953 and PDX10.
If they make a N.A. version I'll be first in line.
Shawn Mielke September 29th, 2003 10:01 PM
The PDX10 feels like it's built for life. It is serious construction. Can't speak for the dv953.
Frank Granovski September 30th, 2003 12:02 AM
The PV-DV953 feels like it's built for life. It is serious construction---like with the PDX10. :).
Yik Kuen September 30th, 2003 04:52 AM
To me the MX500 (I'm holding one right now) shows more grainy pictures under low light than PDX-10 (assuming the same as my previous 950).
PDX-10 should be slightly brighter than MX500 and it still produces 'usable' pictures at 18dB max gain.
However, the upcoming GS-100 (in Japan) should have this problem improved.
Steve Nunez September 30th, 2003 08:23 AM
OK, so in a nutshell for the extra cost you get
1. Slightly better low light performance- but not much better.
2. Arguably, better construction quality.
3. XLR input and markedly better audio.
4.Wider angle of view at 16:9 mode
5.Possible better contrast handling.
The PDX10 does seem like a small step up in performance to the 953, but definitely not a giant leap.....great- thanks to all whom responded. If anyone else cares to add additional observances- please do.
Tom Hardwick September 30th, 2003 08:28 AM
I'm slightly concerned to read that the MX500 doesn't see more wide-angle when switched into the 16:9 mode as the PDX-10 does. If the Panasonic truely is using the entire width of the mega-pixel chips then it should immediately give a wider field of view when switched to the 16:9 mode. In light of this I'd stay with the Sony if 16:9 is important to you.
tom.
Tommy Haupfear September 30th, 2003 08:54 AM
Here are a couple of pictures explaining how 16:9 is derived from each cam.
PDX10
http://img.villagephotos.com/p/2003-5/74415/PDX10.jpg
DV953
http://img.villagephotos.com/p/2003-...IYZP-1-1-5.jpg
Even though I like my PDX10 a lot more than my DV953 its hard to argue with a $1000 price difference. Buydig.com has the DV953 right now for $1022. If you want to stay with that price range but get higher quality 16:9 and retain optical image stabilization take a look at the new Canon Optura Xi. It lacks 3CCD but has a much improved color filter to set it apart from other single chippers.
Ignacio Rodriguez September 30th, 2003 09:35 AM
The important thing is not the angle of view in itself. It is that the angle of view change is telling you for sure that more pixels of the CCD are used for 16:9 mode. But the important thing is that the CCD has enough real pixels to generate the best possible 16:9 image. If the CCD is a megapixel CCD, it most likely does.
Frank Granovski September 30th, 2003 01:43 PM
The PV-DV953, though slightly smaller, is just as solid as the TRV950/PDX10. Go see for yourself. Plus it's a way easier to hold.
