-   Sony RX CyberShots and CX Series Camcorders (https://www.dvinfo.net/forum/sony-rx-cybershots-cx-series-camcorders/)
-   -   RX10 methods to get continuous recording (https://www.dvinfo.net/forum/sony-rx-cybershots-cx-series-camcorders/524352-rx10-methods-get-continuous-recording.html)
Matt Thomas August 1st, 2014 09:18 AM
What are the options/methods to get continuos recording out of a RX10?
I presume you'll need a HD recorder of some sort and someway to extend battery life, is there a ac for it? Whats cheapest you can get it to record continuously?
John Mitchell November 12th, 2014 10:09 AM
Re: RX10 methods to get continuous recording
Matt the cheapest recorders I know of are the BMD Hyperdeck Shuttle 2 (which I'd hesitate to recommend as it is a handy but flawed piece of equipment) and then I think maybe Atomos has a few more reliable units that are a little more expensive. Atomos is or is just about to release the Ninja star which is cheaper than the HDS2 but uses only CFAST media which is currently much more expensive per gigabyte than SSD storage.
At $695 the Ninja 2 is IMO the best option for the RX10 but it is more than 50% cost of the camera..
Powering is the easy bit - you can get a powered battery adapter and the battery housing on the RX10 comes with a port so the cable can easily come out of the camera and the door can still be closed. I'm not sure if any of the site sponsors stock it - being in Australia I bought mine on a well known auction site..
However stopping the camera from turning off is more difficult as it has auto powersave option that can't be disabled only set to a maximum of 30 minutes. I have read you can get around this by half depressing the shutter button but I'm not sure you can do that unattended..
