-   Sony NXCAM NEX-FS100 CineAlta (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/)
-   -   Is HDMI output still uncompressed when recording internally on SD cards? (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/521528-hdmi-output-still-uncompressed-when-recording-internally-sd-cards.html)
Amir Qureshi February 6th, 2014 05:51 PM
Or is the camera sending AVCHD compressed signal out its HDMI output?
I understand that while in standby mode, the live output from HDMI is uncompressed 4:2:2. But wanted to make sure that it is still the case once the camera begins recording AVCHD on its SD cards.
I am going to be using an external recorder for my main recordings, but if the HDMI output is always uncompressed 4:2:2 (wether recording internally or not) then I could record simultaneously internally and on the external recorder. This way I could use the internally recorded AVCHD files as proxies for offline.
Thanks.
Chris Medico February 6th, 2014 07:23 PM
Re: Is HDMI output still uncompressed when recording internally on SD cards?
The live video from the HDMI port is always uncompressed 4:2:2. When the camera is recording to the SD card the live video is the same as when its not recording.
Amir Qureshi February 6th, 2014 10:22 PM
Thanks Chris.
