-   Sony NXCAM NEX-FS100 CineAlta (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/)
-   -   File numbers (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/513462-file-numbers.html)
Daan van Bergen January 13th, 2013 01:47 PM
File numbers
Hai !
A question ;-)
Every time, when I format a SD card, the FS100 begins with the same number : 00000.MTS and counting.
Does anybody knows a trick to have exclusive numbers ? (so new numbers, every time , even when I format a card)
I was used to that, with my Canond 5D
rgds, Daan
Chris Medico January 13th, 2013 02:54 PM
Re: File numbers
I don't see where there is a setting to maintain shot numbering between cards.
Daan van Bergen January 13th, 2013 03:00 PM
Re: File numbers
Sorry.. Maybe I'm not clear.
I 'm looking for a setting in the camera, where the numbers will count from 00000.MTS to >> . So every clip that was shot with the FS100 wil get an unique number.
Chris Medico January 13th, 2013 03:05 PM
Re: File numbers
There is no setting for that.
Bill Pryor January 14th, 2013 10:30 AM
Re: File numbers
The timecode is on the files and will run continuously but there doesn't seem to be any way to have a counter number continuously, like on the 5DII or other DSLRs. I haven't yet figured out how to see the timecode in Premiere Pro.
Eric Olson January 14th, 2013 07:31 PM
Re: File numbers
AVCHD was designed so any computer with a DVD burner running Windows 95 or better could be used to make AVCHD disks. To achieve this design goal the camera uses a FAT32 filesystem, breaks longer videos into 2GB chunks and creates a complete BDMV catalog which can be burned directly to disk and played in compatible bluray players. However, I suspect most NEX-FS100 owners don't use Windows 95 to make AVCHD disks and would prefer if the video files could be longer than 2GB and had distinct numbering.
