-   Sony NXCAM NEX-FS100 CineAlta (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/)
-   -   PP for low light Fluorescents? (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/505662-pp-low-light-fluorescents.html)
Mark Weisen February 28th, 2012 04:05 PM
Shooting B roll in hospital hallways...Shooting with kit lens (although I have several Canon FDs) - First try came out very yellow....Any advice/suggestions on white balancing or a picture profile for these conditions?
John Mastrogiacomo February 28th, 2012 08:43 PM
Re: PP for low light Fluorescents?
How did you white balance?
Mark Weisen February 28th, 2012 10:34 PM
Used 18% gray card or the indoor preset -
Oren Arieli February 28th, 2012 11:00 PM
You might be best off shooting it flat, especially if there is a strong color cast. If you 'bake in' a highly saturated image and the colors are off, you'll be fighting an uphill battle in post. If you have access to a pop-up or solid black/white/grey chart, I would suggest using it.
Doug Jensen February 29th, 2012 05:24 AM
Personally, I would never shoot under any man-made lighting using Preset (no matter what value it is set for) because there's no way to tell if the lights you're working under just happen to be exactly the same temperature as the value of the Preset. The odds of the two being the same are pretty low, and if you're working with fluorescent lighting, there's almost no chance preset it is going to be correct. Using Preset indoors is just asking for problems.
Under man-made lighting I always set a manual white balance. I find a white card works better than a gray card even though technically they should both be the same. Under ugly greenish fluorescent hospital lighting I'd almost always go with a Minus Green card from my set of WarmCards. That's exactly the kind of shooting situation it is made for.
WarmCards - White Balance Reference System
If I can get the WB correct at the time of shooting, then I can save myself a whole lot of grief color correcting in post -- and by taking a couple of seconds to set a proper manual white balance -- it is pretty simple to accomplish. White balancing an FS100 is no different that white balancing any of the other cameras I've used in the past 30 years, but you have to stay on top of it and re-white balance anytime the lighting has changed even a little bit. "Fixing it in post" is not my preferred way of working.
