Taking WB measurments to store in A/B
Below is the relevant excerpt from the user manual:
"To save the adjusted white balance value in memory A or B 1 Set the AUTO/MANUAL switch E to MANUAL. 2 Press the WHT BAL button A. 3 Set the white balance memory switch to A ( A) or B ( B). 4 Capture a white subject, such as white paper, full-screen in the same lighting condition as the one in which the subject is. 5 Press the (one push) button C. The adjusted value is stored in A or B. The stored color temperature appears for about 3 seconds" Nowhere is it said that for the procedure to work, the camera must be in Stand-by mode. And yet it doesn't work while rolling - is it normal? With my EX1, I can push and adjust AWB without stopping recording... I'm not ranting - just want to know whether my unit is functioning normally :) |
| All times are GMT -6. The time now is 10:25 AM. |
