-   Sony NXCAM NEX-FS100 CineAlta (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/)
-   -   New picture profiles (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/503150-new-picture-profiles.html)
Frank Glencairn November 30th, 2011 01:36 AM
Here are some picture profiles I made for the Sony FS100. This is work in progress. I get a lot of input from fellow filmmakers and I learn something on every shooting with the FS100, so I try to improve those settings, to get the best out of that great little camera.
Free Picture Profiles for the Sony FS100 Frank Glencairn
Every input, that helps to make the profiles better is appreciated.
Have fun,
Frank
Keith Moreau November 30th, 2011 02:25 AM
Re: New picture profiles
Thanks for doing all this for the community. I used your GLOG-A on a low-ligtht shoot the other day and it did very well. I've loaded all your profiles into my FS100, using a combination of yours and the Abel Cines. Do you have any reverse LUTs available for your G-Log profiles?
Frank Glencairn November 30th, 2011 02:31 AM
I´m working on it.
Frank
Keith Moreau November 30th, 2011 02:48 AM
Frank, I got a great reverse LUT for the Technicolor 5D Cinestyle that I got from Powered by Doteasy.com that was a RGB Curves preset for Premiere Pro (what I use nowadays for editing after ditching FCP). What do you use? If premiere and you want to create a RGB Curves preset that would be awesome. As it was I applied the Cinestyle LUT to your PPs and this was a pretty good starting point.
