-   Sony NXCAM NEX-FS100 CineAlta (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/)
-   -   Connecting flash memory unit o pc (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/501106-connecting-flash-memory-unit-o-pc.html)
Bruce S. Yarock September 27th, 2011 06:12 PM
I just transferred clips from the fmu 128 flash memorey drive to the pc, and removed the drive from the fs100 before conneting it by usb cable. I notice that there's a small usb plug on the camera itself, towards the back of where the flash unit sits, and right under the xlr input. Can you capture directly from that plug without removeing the flash memory from the pc.?
Bruce Yarock
Piotr Wozniacki September 29th, 2011 07:04 AM
Re: Connecting flash memory unit o pc
Interesting question....
I'm not using the 128GB Sony flash unit, but I often dump my SD card to an USB HDD in the field - works great! FYI, I'm recording redundantly to the nanoFlash, but still considering to give it up (need the nF for other purposes), and buy the 128GB flash unit...
Bruce S. Yarock September 29th, 2011 11:08 PM
I guess I'll just have to try it.
Bruce Yarock
Doug Jensen October 1st, 2011 10:36 AM
No.
You can use the camera to transfer clips from a memory card, but you cannot use the camera to transfer clips from the FMU. The FMU must be removed from the camera and connected directly to your computer via USB. This, and other FMU oddities, are covered in my training DVD. Mastering the Sony NEX-FS100 training DVD
Bruce S. Yarock October 1st, 2011 10:39 AM
Thanks, Doug. I'll order your dvd.
I somehow lost the plastice cover that comes with the camera and needs to be removed in order to put in the drive. Any idea where I can get a replacement?
Bruce Yarock
