-   Sony NEX-VG10 / VG20 / VG30 / VG900 (https://www.dvinfo.net/forum/sony-nex-vg10-vg20-vg30-vg900/)
-   -   A question RE sound... (https://www.dvinfo.net/forum/sony-nex-vg10-vg20-vg30-vg900/505551-question-re-sound.html)
John Vincent February 24th, 2012 08:14 PM
Pretty simple question - can the VG20 record from both it's mic and an external mic at the same time (presumably to separate channels)?
Or do you have to choose one or the other?
Werner Graf February 25th, 2012 02:42 AM
Re: A question RE sound...
Just one Option at the time, as soon you plug in an external mic, internal is switching off.
I found out the VG 20 Microphone channel has a Delay on the Headpone Output ,dont know why...
Steve Mullen February 25th, 2012 04:33 AM
I suspect the delay is from the DSP used for audio.
Werner Graf February 25th, 2012 05:50 AM
A DSP is not cheap and maybe needed with with the 5 CH Surround. But for 2 channel Stereo wrong design, simply pass trough should be possible.
John Vincent February 27th, 2012 07:15 AM
Thank you gentlemen, that's good to know.
