Just remember, for video sharpness is NOT an issue--very soft lenses will seem plenty sharp at 1080 SPEED is.
No lens you buy should be slower than f/2, unless it's a 2.8 zoom. |
Actually I just looked at the shipping note and the lens that is on its way is a 50mm 1.8. No idea where I plucked 2.4 from!
Well I've done some more testing tonite.
The hand-limit for a steady hold is 35mm without the OS of the e-mount lenses. At 40mm you simply can not hold it perfectly steady. Which is not to say 40 + lenses would be worthless--on a monopod, or for the 'shaky' cam effect, hehe. With this in mind there are two routes to high quality hand-held low-light filming. 1) Fast primes. F/2 seems adequate, but the sigmas mentioned above are really the ultimate, esp the 20, 24, and 30. These can be bought in alpha mount and used with LAEA1 OR bought in nikon mount and used with certain types of 35USD nikon G adapters which allow aperture control. 2) Fast Zooms. After some research there are several candidates,from about 250 to 1300USD, first 2 must be bought used around 250USD if you are patient. So, for 285USD (with adapter) you are in low-light business. Cheapest: Tokina 20-35mm f/2.8 AT-X PRO AF More money: Nikon 20-35mm f/2.8 Review A bit more Tokina 16-28mm f/2.8 AT-X PRO FX next: Nikon 17-35mm f/2.8 or Nikon 17-55mm f/2.8G AF-S review test © 2004 KenRockwell.com these are all constant f/2.8: there are no faster zooms. They will not match a f/1.8 prime in low light but should be dramaticaly better than the kit lens. They are expensive (except for the first two) but they replace at least 3 prime lenses. You should be able to find low-light video samples on youtube or vimeo for most of them. All will be MF of course. Only Nikon or alpha mount will offer aperture control. |
Many thanks Charlie, these posts are a real help and much appreciated.
The sony DT series is looking like a bit of a godsend at the moment for those of us assembling primes on a budget... |
My Pleasure, sir.
One thing to remember is that these lenses hold value. Much more so than most cameras. How much? Just check completed listings on Ebay. Watch out for the very high "buy it nows" which are there for every famous lens at 200% or more of acutal value. However, other times you can do well with Buy it now. mflenses.com has ALOT of info on every lens you can think of, and they are quite nice. best, |
| All times are GMT -6. The time now is 04:49 AM. |
