Sony Dual Battery Charger
Hay guys,
I'm looking at getting a couple of Dual battery chargers for my EA50 Sony batteries and I also have some LED lights that take the same style batteries that work really well. I'm looking to setup a charging station and I was looking at |
Re: Sony Dual Battery Charger
I still use the dual charger that came with my Z7 http://www.bhphotovideo.com/c/product/813535-REG/Sony_acvq1051d_AC_Adapter_Quick_Twin_Charger.html
It doesn't charge them simultaneously but the LCD display tells you the state of charge etc and it can also be used to power the camera from the mains electricity. |
Aaron Jones, that model is a ultra-cheap dual charger, the quality is very very low. DO NOT BUY THAT STUFF. i got the single bay model and it burned in a few uses.
please, only use genuine sony chargers. cheap knock-offs does not worth it. |
LOL! Thanks Marlon, after looking at more options I ended up getting a SONY CHARGING DOCK AC-VQ1050B USED on ebay for $35 is good shape. waiting on it to arrive. I also got a cheapo charger just for my LED light batteries seeing that they came with a single bay cheapo and they are cheapo Sony batery knock offs. Here is the cheapo charger @ Amazon.
So now i have 3 LED lights 2 of which uses 1 battery and the third uses 2 batteries. With the single bay charger that came with each one and the double I just purchased I can charge all batteries at the same time. I have the Sony AX2000 Camera and i use a NP-F750 Battery. I have the EA50 with the NP-F970 battery. The EA came with a single bay OEM charger and the AX came with an adapter to charge the battery while attached to the camera. With the Sony Dual charger I have on the way I should be in a better position when it comes to charging. I hate when I have to charge one battery at a time instead of doing it all at once. I'm getting my charging station set up to be more efficient. |
Aaron,
Most chargers that also work as a mains power source for the camera disable the battery charging current when they are plugged into the camera. They will not do both simultaneously. I would check yours carefully so you don't think you are charging a battery when your not. Steve |
Hi Steve, Thanks for the feedback I have the Sony dual charger now. I just received it and i love it. yes it charges both batteries one at a time but that is great because i don't have to come and take one battery off then swap with the next one. it automatically goes to the next battery and begins charging. I ordered more lights from So Including my OEM single charger that came with my EA50 and the 2 dual chargers i can charge 5 batteries without having to swap anything. to me that is worth it and saves me time. Especially when i got the Sony Dual chargers for $35 each. |
Edit: Maybe I mis understood. The exception to what I said is the units that charge the battery by plugging the adapter into the camera do both. So, my bad, I am not familiar with the AX. I thought you were referring to your external chargers with an adapter that hooks to the battery slot. They disable the battery charger when hooked to the camera. ie: the system that came with your EA50 Steve |
Hi Steve
On my EA-50 chargers it's not possible to power the cameras and charge as the switching between camera or charging is a manual slide switch which forces you to do one or the other. Chris |
Hi Steve,
Yeah I understand. I was mostly referring to after I'm done shooting and have enough charging bays to charge all my batteries without having to come back and swap them, which to me is a pain cause time is never on my side these days. I work 12 hours a day on most days at a factory. I'm also working 7 days a week when I don't have a wedding to shoot. And now I have been shanghaied to shoot and edit 2 TV shows for 2 of my pastors at church. So time is a premium right now for me. I have 2 more weddings this year and I will be taking a break from them til next year unless one pops up paying enough for me to reconsider. This forum is one of my past time enjoyments reading and learning from you guys. The threads here are pretty awesome ad i receive a lot help that makes a difference and alot of times cut down on editing time by applying what i learn here. Anyway being able to charge all my batteries at once helps where I don't have to be cognitive of swapping them. My duals will charge one at a time but will still charge them both without any assistance from me. With the extra lights have the same style of battery it makes things a little easier for me. I only need one style of charger. I did order the one cheap charger from Amazon and i kind of regret it now that i found the Sony Dual for $35. The cheap charger was for my light batteries anyway and they cam with the little cheapo chargers to begin with. But I would have rather bought the $35 Sony dual instead though. So now it is time to setup up a charging station... |
Hi Aaron
Ok, I would like you to make a note for me about charging video light batteries in the chargers. Most LED lights use a generic battery which is the same size and even uses Sony model numbers but isn't a InfoLithium battery. My Sony chargers will charge my "Sony" light batteries but it seems that they only trickle charge them and it takes maybe triple the time for the charge light to eventually go off ....Also if I measure the voltage after 3 hours they are still fairly low but they do eventually get to terminal voltage in the end. It just takes maybe 3 or 4 times longer than a genuine Sony battery that I use in the cameras. If you notice this, please let me have your comments and results? I was thinking maybe a generic charger might work better with these generic batteries? Chris |
hi Chris,
Will do. I do however have a cheapo dual charger coming but i will try this out as well to see if it is the same as you say. I have found some NP-F750 batteries on Ebay for $25 each. I was thinking of just grabbing enough of them for my lights as well and use the cheapo batteries for back ups. The cheapo dual charger is not scheduled to arrive until the end of the month it looks like (That Sucks!!). So I will have to try the Sony charger until it arrives. |
Thanks Aaron
Appreciated. My Sony L batteries take a couple of hours at most but the eBay "el-cheapos" take the entire day so just wanted to see if you have the same. No big rush at all! |
Well Chris,
I have a big wedding tomorrow. I have the honor of shooting the Middle Weight Boxing Champion of the World Anthony Dirrell's wedding. So afterwards I will take note of charging times. |
Awesome! That will be a feather in your cap! Make sure you make a big deal about it on your website ..brides love videographers who do celebrity weddings ,,that will get you more bookings
I would NOT put my OEM Sony batteries on those el-cheapo chargers that don't have the IC to communicate with the chip in the battery. I don't mind putting after market batteries on the Sony chargers but as has been mentioned here already the eBay cheapies burn out. I think I have killed at least three of them on after market batteries over the last couple of years. Thought I might save a few dollars but how wrong I was. Only use OEM batteries and chargers now. Chris Young CYV Productions Sydney |
| All times are GMT -6. The time now is 04:22 PM. |
