-   Sony NEX-EA50 (all variants) (https://www.dvinfo.net/forum/sony-nex-ea50-all-variants/)
-   -   Depth of Field Question (https://www.dvinfo.net/forum/sony-nex-ea50-all-variants/519482-depth-field-question.html)
Jon R. Hand October 14th, 2013 02:30 PM
with the kit lens, what is the depth of field wide open (3.5) and 18mm (wide) if I focus at object
a) 5 feet (and)
b) 10 feet
c) 20 feet
I'm having a difficult time testing this. Results do not seem to be consistent.
Any standard depth of field chart on the web that would be accurate for this Sony lens on the EA50?
Much thanks.
Chris Harding October 14th, 2013 05:54 PM
Re: Depth of Field Question
Hi Jon
Too easy!! Use this link Online Depth of Field Calculator
Any preset for APSC will work fine ...as far as I remember I use the Canon 7D one. The calculator makes life easy and you can work in feet or metres!!
Chris
Jon R. Hand October 14th, 2013 07:04 PM
Thank you Chris. I used this calculator a while back I believe, thanks for reminding me. Just didn't know which camera profile to use. Thanks again....
Chris Harding October 14th, 2013 10:26 PM
Hi Jon
Very useful stuff and quite often it's a lot easier to switch the camera to manual focus even with the stock lens if your subject/cam distance isn't going to change very much. I find at weddings going around getting guests to say congratulations to the camera I can get focus in auto and then switch to manual as long as I know I'll have enough DOF ...that way the camera cannot focus on the background in auto (which it often does or takes a bit of time to lock on)
5' is a little tricky as you only have a DOF of 3' but step back to 10' and your DOF goes right out to 18' (6' to 24') My secret if I have to work close is a Tokina 11-16 zoom It's fast at F2.8 and as long as you are a few steps away you are always in focus so you can preset the lens. (At 10' it's in focus from 3' to infinity!!)
Chris
