-   Sony NEX-EA50 (all variants) (https://www.dvinfo.net/forum/sony-nex-ea50-all-variants/)
-   -   Please Post High ISO/Gain samples (https://www.dvinfo.net/forum/sony-nex-ea50-all-variants/518392-please-post-high-iso-gain-samples.html)
Chris Quevedo August 18th, 2013 09:27 PM
Hi,
is there a possiblity that someone could post a file into their dropbox of some late night footage at some of the higher ISO/gain settings? i would like to see how these files look for myself, with my own eyes. tired of people saying how grainy it is, but not being able to get my hands on one to see for myself in Premiere Pro how bad it actually is, whether is can be cleaned up with a noise reducing filter or not. just would like to see with my own eyes.
i know i keep saying i'm right on the verge of getting one, but i just am not sure. i'm not getting my money to buy it for a few days. it would help me decide if i can live with it, or if i should hold out for a FS100.
i appreciate it if someone could make this happen, as the low-light tests on vimeo are fine, but it compresses the footage so i don't know how much i can trust it.
Chris Quevedo August 18th, 2013 09:28 PM
Re: Please Post High ISO/Gain samples
i only need a few seconds worth.
Chris Harding August 19th, 2013 12:43 AM
Hi Chris
I'm assuming you need some footage that is purposely grainy ..like a dark dark room and the camera gain allowed to go to 30db?? I limit my gain to 21db so I have nothing that you could call "grainy" as at 21db it's pretty much clean ..even dark backgrounds ... I use an LED light as a fill only for my subject in dark shots which doesn't light the background but at 21db or less it's pretty much flawless.
Maybe someone could take their gain or ISO limit off and let the camera go wild but I really cannot see the point?? If it's too dark exposure wise at 21db or around 3000 ISO then all you do is add light or use a faster lens. It's the middle of the day here so for now I have nowhere dark to film that would be practical!
Let me know later if you find any footage otherwise I could try some later this evening?
Chris
Noa Put August 19th, 2013 01:28 AM
I can give you a bit more, did some iso tests some days ago with my nex-ea50, 550d and gh3, nothing scientific but clear enough for me. On the nex-ea50 I used the pp3 preset which is quite flat, I should have tested with the preset turned of as well because the flatter the preset, the more noise you will see. On the 550d I used the neutral preset and the cinestyle one (here you can see what a flat preset causes) and on the gh3 just the standard preset.
If at the next wedding I have a better example (preferably when there is red lights because that brings out the noise much more) I"ll put my nex-ea50 side by side with the gh3.
If you pm me your emails address I"ll give you a link from the file that is on my google drive.
Chris Quevedo August 19th, 2013 07:15 AM
thanks so much!!!
Chris Quevedo August 19th, 2013 11:15 AM
ok sent you a message with my email address :-)
Noa Put August 19th, 2013 01:20 PM
Just send the link, interested to hear what you think of the results. :)
Chris Quevedo August 20th, 2013 11:06 AM
i don't know if i have the eye to tell the difference. seems all three cameras are about the same
Noa Put August 20th, 2013 11:53 AM
4 Attachment(s)
Here are some (I think 200% crop) frames from each camera, the gh3, nex-ea50 and the 550d there are also 2 frames from the same camera but a different preset (which is why there are 4 frames) curious what others find without knowing which camera they are looking at?
All images are at 6400iso except for the nex-ea50 which only goes up to 5000iso, when I look at the recording on my big screen the nex-ea50 produces the most visible noise to my eye.
I hope I can get a better example at this weekends wedding depending on the lights that are used.
Chris Quevedo August 20th, 2013 12:20 PM
thank you so much for sharing all of this. seems like it can be a lot noisier than i thought it would be
Noa Put August 20th, 2013 02:21 PM
Normally I"m not such a pixelpeeper, I just look at the final image from a normal viewing distance on a HD tv and on that the nex-ea50 showed the most grain but important to know is that certain presets are (much) more noisy, pp3 on teh EA50 is pretty flat and I"m sure if I would have used no preset the result would be different. The 550d looks the worst when you use the cinestyle preset, the image just falls apart.
The gh3 does display clear grain at 6400 iso but is sharper then the others, there is one frame where you need to look at the tv in the top left corner and more specifically the ventilation lines on the side or look at the letters on front of the tv, on the other camera's that's turned to mush while the gh3 still shows the most detail, this should theoretically give a better start point to apply neatvideo when that would be necessary since there is more detail.
Much depends on the light used, when I shot at the last wedding 6400 iso on the gh3 seemed fine to me, but everytime red light was shining the grain appeared much more and it didn't look that pretty, I"ll see what happens this Saturday if I have some demanding low light situation so I can put the camera better to the test. This I need to know how far I can push it before the image falls apart.
Steven Digges August 21st, 2013 12:31 PM
Chris,
Lately there have been several comments about the EA50 being a poor low light performer. In my opinion that is not true. But I have a very sober opinion of it as a $3,500.00 camera. Some guys are expecting miracles from a budget priced camera. I believe you get what you pay for. In that category the EA50 is amazing. It is a feature rich good performing camera, especially for it's price.
And some of the guys complaining about low light and high grain are using the stock lens. Anyone expecting to shoot at ISO 160 at F6.3 in low light is crazy. It ain't going to happen. It is a "KIT" lens. Again, a bargain with short cummings, and damn nice for some things. Fortunately the EA50 is an interchangeable lens camera. Faster lenses are the answer and good glass costs money.
Steve
Chris Quevedo August 21st, 2013 12:37 PM
true steve,
i'm not meaning to throw the EA50 under the bus. we all get what we pay for, and for the price, its pretty awesome. the touch focus and the digital zoom and the fact that it comes with a kit lens that can power zoom is freaking awesome.
Steven Digges August 21st, 2013 12:57 PM
The power zoom is nice, but at its fastest speed it is surprisingly slow to zoom. Butter smooth though.
With all lenses, including manual focus the peaking on this camera is amazing. It makes everything easy to focus spot on. I usually run it in yellow on medium. It lights up everything that is within DOF.
Steve
Edit: Before I say butter smooth some guys have an issue with it jumping. Mine does not, or it is so slight I can't see it. There are threads about it.
Chris Harding August 21st, 2013 06:27 PM
Hi Steve
I have the same opinion too! I love both of mine to bits and have chalked up close to 100 hours on each too.
Chris Quevedo is simply asking many questions and making lots of comparisons because he intends to buy an EA-50 and doesn't own one as yet ... it's pretty tough to make comparisons on the camera if it's not actually in you hot little hands and simply reading and commenting on theory is quite different to actually using it. Chris will be pleasantly surprised when he actually takes delivery of his camera ... it's a great package at a great price!
Chris
