HELP! Need Timecode on TAPE AND Card!?
Using a HVR-MRC1 Recording Unit attached to the back of a borrowed HVR-Z5U. I cannot for the life of me, figure out how to get TIMECODE to show up in the viewfinder or on the tape (I'm recording in DV mode on tape - AVI mode on the card). I can see the timecode on the back of the HVR unit running - but nothing in the viewfinder, or on the tape itself.
I've poured over manuals to both devices, and can't hit on the right combination of settings - I seem to be missing something. ON the Camera Menu I have it in DV MODE (scan type 60 -this is for broadcast and matching another camera) EXTERNAL CONTROL to SYNCHRONOUS On the camera menu _ on the TC settings I've got the TC RUN and then TC PRESET to ooooo then TC FORMAT to AUTO then TC RUN to REC RUN then TC MAKE to PRESET On the HVR-MRC1 I have the unit I-Link set to AUTO the SETTING - TC FORMAT set to AUTO It is my understandting that the HVR UNIT will get the timecode off the camera - which SHOULD be putting it on the tape - BUT NOTHING IS ON THE TAPE. The Timecode numbers do NOT advance in the viewfinder while recording, but the tape and card are recording just fine. HELP me ObiWan. A confirmed Canon user - frustrated by Sony menus. |
believe i can help here
dont worry - it is recording time code- its just not possible to record dv or hdv without any form of time code. in the viewfinder, does it display 00 00 00 00 or 00:00:00:00 if its the former, thats user bits, not timecode its displaying. userbits are just extra data you can record on the tape (maybe to denote camera number), but no-one really uses it. If userbits are diaplyed, timecode will still be rolling on as you record, its just displaying userbits instead of the timecode in the corner. There will be a button somewhere that'll flick between the camera displaying userbit and timecode. Look for a button marked TC/U-BIT, probably near the play/rewind buttons hope that helps |
God Bless You Sir! Yup - did the trick. I couldn't for the LIFE of me figure out why I was recording, but not seeing timecode advance. I had the proper selection INSIDE the menu - but somehow the little button on the VCR control pad must have gotten togled. All is good and I'm off for a long day's shoot.
DVINFONet's vast and unpaid intergalactic research department comes through, once again. Love this site. |
