FUJINON S19X6.5BRM LENS for Sony 270
hi..
will this lens "FUJINON S19X6.5BRM LENS" fit/work with the Sony 270 thanks john |
John, that is a 1/2" lens. So it won't go on without an adapter. Fujinon sells an adapter (B&H about $700.00) that will allow you to mount a 1/2" lens on the 1/3" S270. But I think you will need a lens that has a cable out of it as opposed to a lens that makes contact through the lens mount. From the pics, I am pretty sure the Fujinon adapter does not have any contacts internally. The S19X6.5BRM is listed as a "Sony" lens and it might only have contacts on the lens mount instead of a universal type lens cable connector.
lens
Many thanks
So what are my options for the Sony 270 in manual lens? john |
check thru the forum here-I don't remember who posted it or exactly where but someone here put the Fuji 16X (most notably used on the JVC1xx/2xx cameras) on a Sony Z5 which of course means (to me at least) that it would work on the 270. You might also look at the Fuji 17X (used on the JVC 2XX series)-it might also work.
Please note that I do not own any of these cameras but am going from what I have read right here. If it helps great of not, sorry. Don |
I know Fujinon makes 1/3" lenses and I think Canon does, as well. As far as I know, all of the lenses listed for the JVC 1/3" cameras should work on the S270. I will have some additional news soon because I am anxiously awaiting arrival of my own Z7 and it is coming with a Fujinon 16x lens. TH16x5.5HD if I remember correctly.
Look for this thread "SONY Z7 & JVC HD-100U Fuji 16X kit Lens". Mine should be similar. |
Yes you need a fujinon TH16x5.5 lens as used on the JVC cameras, they work fine and are very good for manual operation.
lens.
Hi gary
were never too far away online! john. |
John, after playing with the Fujinon TH16x5.5 1/3" lens for a day, I have a few preliminary impressions. It would probably work better on the S270 than the Z7. It makes the Z7 a little awkward for me use. It just screams for some short of shoulder support. One negative is that you lose a little on the wide-angle side compared to the stock lens. On the plus side, the Fujinon obviously has more zoom 16x vs. 12x. Plus, it is a faster lens at f1.4 and it will hold f1.4 though out the whole zoom range. So it will have a slight edge in low light conditions. And probably a slightly better chance to control your DOF. I have spent most of my time shooting with broadcast lenses so I like the control. But a friend of mine has spent most of his time with cameras like the V1 and the lack of auto focus is driving him crazy. The Fujinon lens is a joy to work with. All of the controls are really light and easy to use on it. It makes the standard lens seem almost like it is in a bind, by comparison. Now if I could just find a shoulder brace that I like.
Or you could buy a 270???
How fast( zoom speed) was the zoom on the lens you tried , I have the 270 with the standard lens and it is so slow compared to what I am used to( Canon YJ12 w/a on a SONY dsr 570) I dont think Canon make any 1/3 inch lenses that would suit the camera, at least not at a reasonable price. My ideal would be a 15x wide angle ( 80 degrees plus )based 1/3 inch zoom with a fast zoom speed and proper manual focus that didnt cost more than the camera! Come on Canon, you know you want to make one. |
There is only one 1/3" lens from Canon at the moment. It's the KT20x5B KRS. But for the price it is costing, I would definitly go for the Fujinon HTs18x4.2BRM. It's price is a little bit more, but it has all the nice DIGIPOWER functions that are also found on the broadcast models. Also available with 2x extender.
http://www.canon.com/bctv/products/p...x5B%20KRS1.pdf Here is the 1/3" lens folder from Fujinon. http://www.fujinon.com/pdf/2007FPOJVCBrochure.pdf |
