-   Sony HVR-Z7 / HVR-S270 (https://www.dvinfo.net/forum/sony-hvr-z7-hvr-s270/)
-   -   Help with CF unit and final cut v6.0.3 (https://www.dvinfo.net/forum/sony-hvr-z7-hvr-s270/119738-help-cf-unit-final-cut-v6-0-3-a.html)
Gary Nattrass April 19th, 2008 05:07 AM
I recently got the Z7E camera and have been doing some tests to the CF recording unit.
My problem is that I cant get final cut studio 2 to see the CF reader in log and transfer. I downloaded the sony plug-in and I am running FCP 6.0.3 on an i-mac with leopard 10.5.2 and a macbook pro with the same software.
It has never worked with the i-mac but I could see the video files on the macbook until I loaded FCP 6.0.3.
Has anyone else had any problems seeing the CF units files or is there a simple setting that I have overlooked. It is appearing on the mac desktop as a video icon and I can go into the folders but as said the FCP log and transfer doesnt see the CF unit or any files.
Bruce G. Cleveland April 19th, 2008 05:20 AM
To get the mac to see the card you have to click on the little folder icon with the + sign in the upper left side of the log and transfer window. There should be a device named video or whatever your card reader is. Click on that and then on open. It does sometimes take a while to see it and then it should show you what files you have.
Bruce
Gary Nattrass April 19th, 2008 05:32 AM
Thanks for your reply Bruce I have tried that several times and whilst I an see the video folder when I click on it to open nothing happens, I have waited 30 mins.
The one time it did work on the macbook pro last week it just saw the CF unit straight away and I could see the three video files and transfered them fine.
It is only since I went onto FCP 6.0.3 that both machines wont work and I was wondering if any other FCP users have had similar problems.
Clemens Fischer April 19th, 2008 07:20 AM
hello gary!
look at my post:
http://dvinfo.net/conf/showthread.php?t=119742
i am not shure, if i sould update my macbook pro's final cut to 6.0.3
regards,
clemens
Gary Nattrass April 29th, 2008 06:13 AM
I was talking to Sony this morning and they can not find a fix for this so for the moment I cant use the CF unit with my macs running leopard 10.5.2 and final cut v6.0.3
Derek Woods April 29th, 2008 07:31 AM
Do you have anything else connected on the firewire bus? make sure your firewire deck or camera is off before you mount the cf
Gary Nattrass April 29th, 2008 08:49 AM
Thanks for your suggestion Derek but it still does not work!
I had a call from Sony again to say that there was a new version of the plug-in software available from today V1.01-1 I have installed that on both macbook pro and i-mac and it still does not work. I even deleted the old version from the applications menu.
This is most frustrating as the CF unit mounts and I can see all the folders on the desktop and in FCP but it just wont read them into the import box.
Clemens Fischer April 29th, 2008 10:12 AM
here is the link:
http://www.sony.ca/hdv/HVR-DR60_60i/...0/soft.html#A2
regards,
clemens fischer
Gary Nattrass April 29th, 2008 10:42 AM
Originally Posted by Clemens Fischer (Post 869425)
here is the link:
regards,
clemens fischer
That is version 1.01 the latest one is 1.01-1 and is here:http://www.sony.co.uk/biz/view/ShowC...veContext=true
Still doesnt work for me though!!
Michael Liebergot April 29th, 2008 10:49 AM
Gary, do you happen to have the link to that V1.01-1.
Or is Nates link the one that you used?
