FCP plug-in has been released !! for M2T & DV file import
thanks kenny :) has anyone tried this plugin yet? haven't received my unit yet to test the import functionality on, but i'm guessing this is used for simple drag & drop to your FCP bin?
Does anyone know whether a solution for FCE is likely to happen?
Hopefully this means drag and drop and not normal logging in of footage and capture in real time. |
I think it uses the 'log and transfer' window actually, which does mean drag n drop.
How much time does it take to import these clips from the drive
I am thinking about getting a couple of these to speed up workflow with my v1u. I was wondering what the time difference is between using the log and transfer versus using tape and the log and capture.
Thanks Ben |
Is this the same plugin that has been out for a month or so now or a diffrent one? Bruce |
Imoprting M2T files at high speed?!!?!
Hi there all,
I spoke to Sony and this is a new plug in. I have Final Cut 6.03 and I can capture the footage in real time when playing back from the device. (I press menu, chose HDV and press play, so I assume the device is not in "computer mode") However, when I do this a dialogue box comes up saying that I didn't remove the device properly?!?! Seems to work though. However... ...I can't figure out for the life of me how to import/drag and drop the files to increase the transfer rate of my footage. Has anyone done this high speed capture successfully and if so, what settings do you have on your capture presets? Mihali |
Kenny, thanks for the link!! I’m running System 10.4.11 with FCP 6.0.3, using 16gb Sandisk Extreme III cards with an Extreme IV firewire 800 reader - and it works flawlessly from the “log and transfer” dialogue. Now all we need is preview and mass metadata editing, and we are beating P2 hands down!
thanks clemens |
Clemens, Not as of yet. I will be shooting much more in the coming days, and will follow up if I begin to get errors
I have managed to work out how to log and transfer data from my CF card to final cut pro 6.0.3.
However, it seems that even when I shoot in 25P on my Z7, the clip settings do not match my sequence settings which I have set to HDV 1080p25. Final Cut asks if I want to change the settings to match my clip settings. When I say yes, the sequence turns into HDV 1080i50. I have also noticed, that in the compressor column in my browser all the clips have HDV 1080i50. Am I missing something in the log and transfer window? (My audio/visual setting in the menu are set to HDV 1080p25). I can't seem to find anything to alter capture settings..... |
I think maybe the 25p it uses is actually a type of 50i where both fields are the same. This is so it can be edited as 50i, although I'm not sure why.
can anyone preview in log and transfer?
I'd like to be able to just take portions of a clip & not the whole thing, but it looked like I couldn't set ins & outs, just drag an entire clip into the bin. |
Apparently not supported for .M2T files.
| All times are GMT -6. The time now is 02:43 AM. |
