-   Sony HVR-Z5 / HDR-FX1000 (https://www.dvinfo.net/forum/sony-hvr-z5-hdr-fx1000/)
-   -   Lens adapter for Depth of Field FX (https://www.dvinfo.net/forum/sony-hvr-z5-hdr-fx1000/475782-lens-adapter-depth-field-fx.html)
Mike Mona March 28th, 2010 09:21 PM
What lens adapter do you know that I can use with my FX1000 and get the depth of field effect?
Thank you,
Mike
Dale Guthormsen April 1st, 2010 08:59 AM
1 Attachment(s)
I have not used this, (350 bucks) but if it can go on an xl1 it can go on the 72 mm thread of a fx 1000.
The CineCity*::*DOF Adaptors*::*Cine 35mm Dof adapter with Vibrating Ground Glass for xl1 xm2 GL1 GL2
More expensive: at 1200 bucks
http://www.bhphotovideo.com/c/product/552530-REG/Cinevate_Inc_72_1LE_FL_MP2_72_1LE_FL_MP1_Brevis35_Imaging_Kit.html
Have you tried shooting at the further end of your zoom and using your nd filters+ an exterior nd and perhaps a polizer to allow you to open up your aperature and therefore have shallower depth of field??
It is quite surprising how decent that can be.
I just took this pick in the kitchen with my fx 1000, the pepper mill is about 30 inches behind the clock. It a bit grainy but you can get the idea what you could do without out an adapter.
Dale
Mike Mona April 1st, 2010 08:55 PM
Dale, thank you verry much for your help. Your shot looks interesting. I'll try my polirizing adapter, see if I can come up with something.
thanks.
Dale Guthormsen April 2nd, 2010 11:53 AM
Mike,
Glad to help when I can. I have had tons of help from this group over the years!!!!
I might add, if you were going to shoot an entire indie film and want the shallow depth of field I would use the adapter as I think you would get more consistancy from the various exposures you would run up against throughout the shots. If it is only a hand full and you can conrtol the light circumstances then you could get by without one. You just need to set up shots a little better considering the light and subject placement.
I am sure others could contribute here more than I can.
dale
