-   Sony HVR-Z5 / HDR-FX1000 (https://www.dvinfo.net/forum/sony-hvr-z5-hdr-fx1000/)
-   -   How to loose a Polfilter (https://www.dvinfo.net/forum/sony-hvr-z5-hdr-fx1000/237763-how-loose-polfilter.html)
Dirk Pel June 22nd, 2009 04:43 AM
Who knows a trick to loose a polfilter. After screwing the filter on mmy Z5, not too tight, I had a lot of problems to loosen it again.
Dirk PEL
Luc De Wandel June 22nd, 2009 05:10 AM
Don't try to unscrew it with your fingers grasping on the sides of the filter, but instead put the full palm of your hand on the entire filter rim and try to unscrew it like that. Works most of the time, because the pressure is more even.
Dirk Pel June 22nd, 2009 05:44 AM
Thanks Luc,
The problem is that the Hoya HD Polarisingfilter in front is turning around and the part that is screwed in the Z5 is very small.
Dirk PEL
Jo Ouwejan June 22nd, 2009 10:31 AM
Try to wind a piece of insullated electrical wire around the part that got stuck. When both ends meet, bend them in a radial direction outward and pinch the ends between thumb and pointing finger, close to the diameter. Now turn counter clockwise.
Chris Soucy June 22nd, 2009 05:16 PM
Hi Dirk................
Get a narrow rubber band and stretch it over the fixed filter circumference (like a bicycle tyre on a rim).
Grip and turn. Hey presto.
CS
Dirk Pel June 23rd, 2009 01:31 AM
Hi,
thanks a lot for the suggestions, with the rubber band it functions!
Dirk PEL
Bill Ackerman June 23rd, 2009 01:39 AM
I keep one of these in my bag at all times. Have only had to use it once, but it took a second to remove a balky step-down ring:
General Brand | Filter Wrench (Set of 2) | B&H Photo Video
Paul Tauger June 23rd, 2009 11:30 AM
I use a flat rubber drain stopper. It's difficult to describe, but you can find them in any hardware store. It's a flat piece of thin textured rubbered about 4 inches in diameter. I've been using these for years and they always work, no matter how "sticky" the filter.
