-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   Sony ECM-NV1 mic on FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/92920-sony-ecm-nv1-mic-fx1.html)
Rickey Brillantes May 1st, 2007 02:02 PM
Hi! Is this mic the one they use for the PD150 or 170 compatible with the FX1 assuming that I have the Beachteck XLR Adapter? Do you think this will work?
Thank you.
Boyd Ostroff May 1st, 2007 02:05 PM
It should work as long as your Beachtek box provides phantom power. I have used this mike on my Z1 with the built-in XLR's and it worked fine.
Rickey Brillantes May 1st, 2007 02:10 PM
Thanks Boyd, the Beachteck im using was designed for the FX1, and it requires a 9 volt battery to use it...is that the phantom power your refering to?
Boyd Ostroff May 1st, 2007 02:18 PM
Probably, but look at the specs on their website here to be sure: http://www.beachtek.com/prod.html
Rickey Brillantes May 1st, 2007 03:08 PM
Thanks for the link, I have the DXA-FX and it did'nt mention anything about phantom power.
Boyd Ostroff May 1st, 2007 05:31 PM
Unfortunately it appears that this adaptor won't do it for you. The NV1 requires phantom power. According to the manual posted online:
This adapter is designed to easily attach balanced or unbalanced type microphones to this camcorder (condenser type microphones require their own power as the adapter does not supply phantom power)
