FX1 and Mic Line In
I recently purchased my first shotgun mic for my FX1, a Rode Videomic.
Unfortunately there appears to be an issue with the audio coming in through the mic/line in plug. For some reason there is barely any audio coming into the camera. When I have the audio levels set to auto, it is as if the mic is not pickup up any noise. If I set the audio levels on the camera to manual and increase it to 10 (the max), then I begin to hear things if I speak very loudly. This seemed really odd for a mic that most people refer to being very sesitive. I decided to check to make sure the mic was working by attatching it to my old TRV900. The video mic worked and sounded amazing on that camera. Therefore, I believe that something is wrong with my FX1. Does anyone have any idea what the issue might be? Or better...how I might be able to fix it? Thanks so much! |
On pp 56-57 of the US manual it talks about how to select MIC or LINE for the input.
Apologies if you've done this already... |
Yes. Make sure mic in is selected in the Audio set menu.
Also make sure you are pluged into mic/linein, not audio/video plug... |
| All times are GMT -6. The time now is 01:13 AM. |
