-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   Sony FX1 or Sony FX7? Best image quality? (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/82269-sony-fx1-sony-fx7-best-image-quality.html)
Adriano Moroni December 21st, 2006 03:02 PM
Hi, I make only documentaries around the world, often in the rainforest.
I look for the best image quality. In your opinion what is the best image quality between Sony FX1 or Sony FX7? 3CCD or 3 CMOS?
Thanks a lot
Gareth Watkins December 22nd, 2006 02:11 AM
Hi Adriano
I don't think you'll find a huge difference in picture quality between these two models... Certainly not enough to base a choice of camera on...other than perhaps the low light capacity which would be better on the FX1.
However the ergonomics of each model is quite different.
FX7 is smaller and lighter. The FX1 is quite a bit bigger which may be an issue for hand held shots for you...
I've owned an FX1 and now have a Z1 and find them both excellent cameras. I love the top mounted LCD screen and the excellent aperture wheel. I personally find the larger camera easier to use, especially with a shoulder support...
Finally if you want the best audio, the Z1 has far better audio functions than the FX1. I used to had a Sign video box on my FX1 but the extra adjustments, phantom power, trim, etc you get on the Z1 has improved my audio quite a bit.. worth considering if your budget stretches to one!!!
Regards
Gareth
Adriano Moroni December 22nd, 2006 03:03 AM
Hi Gareth, thanks for your interesting reply. Now I use Sony VX2000 and its size satisfies me. Can you tell me if Sony FX7 is smaller than Sony VX2000?
The interesting matter for me is the Sony FX7 sucks less power from batteries.
I never worked with a very small camera and if Sony FX7 is too small I am worried.
A different question: I have the feeling that Sony FX1 will have a short life.
I don't like about FX7 is the CMOS is 1/4. FX1 has 1/3 CCD.
Thanks again.
Evan C. King December 22nd, 2006 03:36 AM
The vx2000 and fx7 are roughly the same size.
Gareth Watkins December 22nd, 2006 04:23 AM
Hi
As Evan says if you are happy with the size of the VX2000 then you'll be fine with an FX7...
As to the life of an FX1... well all cameras these days have a short life, as technology gallops... If you wait for the next thing just around the corner, you'll be waiting more than shooting. It's a fine camera... and that won't change, evenif it is replaced in the next couple of years.
Finally having used the FX1, as I said above, I'd no longer opt for a camera that doesn't have XLR inputs... I wasn't convinced until I got the Z1 of the advantages..
cheers
Gareth
Norman Reid December 23rd, 2006 07:01 PM
I have a FX1 and the audio issue came up as soon as I recorded a somewhat loud concert. Even though I manually set the input so that the peak levels didn't go in the red, the audio still came out distorted. I bought the Beachtek DXA-FX for the XLR inputs and a Rode videomic and now by sound is outstanding.
Theodore McNeil December 23rd, 2006 10:34 PM
Check out this link from the FreshHDV Blog...
It a google translation comparison of the FX1 and FX7... The original page is in German//
http://translate.google.com/translat...language_tools
Stu Holmes December 24th, 2006 11:23 AM
Sorry this is off-topic....
I have exactly this same problem. With my Videomic on my standard-def DV cam i manually set the levels at a loudish concert recently and carefully made sure it wasn't "red-lining".
But..it still came out completely distorted. I think the Videomic level just overloads the cam's pre-amp and thats that even if you turn levels down.
Looks like I might get a Beachtek box then or something like yourself.
Can i ask if you mean you're still using Videomic with an XLR box?? It would make more sense i guess to use a balanced mic like NTG2 or NTG1. But i guess Videomic would work fine as long as you had a minijack-to-XLR converter.
Norman Reid December 24th, 2006 06:06 PM
The problem is not with the videomic. The FX! do not have a way to set attenuation. I have a Canon GL2 and it has a way to set a limiter and there's no problem with distorted audio. The Sony is another story. The Beachtek allows you to hook up an external mic and you can set the attenuation and get around the distortion problem.
Carlos E. Martinez December 25th, 2006 12:49 PM
Even if I believe the reasons for the distortion might be somewhere else in the FX1, you should partner it with a better mixer/preamp to get better audio results.
Something like the SD Mixpre should provide excellent results, or the ENG44.
The preamps are better and the control capability even more. They also have limiters, which are essential to avoid overload.
You also get into the FX1 with line levels, which are usually flatter.
Jim Coontz January 2nd, 2007 07:15 PM
Sony FX1 or Sony FX7? Best image quality? REPLAY
THe FX7 is a 1/4" chip while the FX1 is a 1/3" chip.
The FX1 has a better image by far.
Justin Carlson January 3rd, 2007 09:24 AM
Because of the different technologies, you cant just compare the sensor size.
That's like saying a 2.5 litre engine is better than a 1.8 litre engine. There's more to it than that.
Stu Holmes January 3rd, 2007 10:39 AM
Jim - As Justin said there's relatively little validity in comparing these CMOS and CCD sensors.
In fact, take a look carefully at all the comparison shots of FX7 and FX1 , very competently done on this site :
http://www.fxsupport.de/12.html
and you will see that your statement "The FX1 has a better image by far" is essentially wrong.
Richard Iredale January 3rd, 2007 11:32 PM
Camcorderinfo did a recent review of the FX7. As I remember it, the video quality was great a high light levels, but worse than the FX1 at moderate and low levels.
Jim Coontz January 3rd, 2007 11:43 PM
Sony FX 1
I have been shooting with a sony FX7 & FX1 for over 2 years. Most of the time we shoot HD and it gets edited DV. But we do edit HD sometines and the FX1 is the camera you want to do this with. It holds whites better with out blowing them out. I also shoot with Sony 900 series. At times the FX1 can look just as good. Its all in the lighting. If you know about lighting you can make a any camera look good to a point. But I wouldn't trade a 900 for a FX1 and I would not trade a FX1 for a FX7. This is not from a web page test its from someone that shoots most every day.
