Z1 = Upper field ???
Hi all,
I just finished some editing with footage taken from a Z1, this was shot by my collaborator and it was my first attempt at HDV. Everything went smoothly. I notice though the native field order was "upper". I thought those HDV cameras shoot in progressive mode. Do you think I should set my edited work to progressive then, this will go on a DVD and won't be broadcasted in any conventionnal way. Thanks Phil |
The Z1 does not shoot in progressive mode, it's an interlaced camera. It does have cineframe 24, 25 and 30 psuedo-progressive modes however which you can activate in the picture profiles.
Thanks Boyd
1080i HDV is indeed upper field first.
heath |
Footage from the Z1 being downrezzed to SD profits - at least in Premiere Pro - from de interlacing the output while using Adobe Media Encoder.
I'm sure this isn't a revelation to the old hands here :-) |
But there are different ways to deinterlace. The simplest is just discarding a field, as you note. Not familiar with the PC, but FCP just removes a field. There are other solutions for "smart deinterlacing" however where moving parts of the image are processed differently from static portions. Graeme Nattress makes an FCP plug-in: http://www.nattress.com/Products/fil...eInterlace.htm Joe's filters is another plug-in option for FCP: http://www.joesfilters.com/joes_deinterlacer And there is DVfilm Maker which runs as a standalone program on the PC and Mac: http://www.dvfilm.com/maker/ There are also other solutions out there. |
Am I wrong or VirtualDubMod does the deinterlacing... for free!?!? Carlos |
ciao, Matt |
| All times are GMT -6. The time now is 09:18 PM. |
