-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   Fx-1 to (ahem) VHS? (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/73944-fx-1-ahem-vhs.html)
Darin Boville August 20th, 2006 11:34 AM
Fx-1 to (ahem) VHS?
O.K., amybe I'm missing something obvious.
I have a request to dupe a series of tapes I shot with the FX-1 to VHS.
I want to simply dupe them--no editing, no computer, etc. Low work, high speed is the key to meeting this job's price point.
I shot in HDV (widescreen, of course). When I dupe to VHS I get a sqeezed image. I want a letterboxed image.
Is there a setting or a workaround? I know I can take it into Final Cut and adjust things but that will take too much time--I would love to do it direct.
Alternatively, is there a direct-to-DVD recorder that will unsqueeze and add the black bars? I would be happy to buy a new box if that was the right answer.
--Darin
Mack Fisher August 20th, 2006 11:59 AM
Is your TV option on your camera at 4:3 or 16:9?
Boyd Ostroff August 20th, 2006 12:22 PM
The Z1 has a choice of 4:3, Letterbox and squeeze in the downconvert menu. Not sure if the FX1 has these however. But the DVD recorder is really a much better idea - instead of making VHS tapes. Or did you just want to use the DVD recorder as a pass-through to do the letterboxing on a VHS tape? If so, then I'm not sure it will work. Well, at least on my Sony RDR-GX7 you can't do this.
But you can record an anamorphic DVD, which would give you the highest quality from your FX1. When an anamorphic DVD is used on a player connected to a 4:3 TV then the player will do letterboxing.
But check the specs on the DVD recorder before buying. Make sure it has the option of creating a 16:9 DVD. Awhile ago we had a thread where someone went through several models of inexpensive DVD recorders which couldn't do this.
Chris Barcellos August 20th, 2006 12:50 PM
Under the in/out menu, you can select TV type you are going out to. I am guessing that will automatically letter box the output for you if you select 4:3 and take it out by composite to the VCR.
Darin Boville August 23rd, 2006 02:14 PM
Just getting back to this job--
Thanks for all the posts--the TV selector menu item worked like a charm--bravo!
--Darin
