What should I shoot 4:3 or 16:9?
I have a video for TV and for hd projection - what is the best way to shoot it? Since I have already shoot some stuff in 16:9 (native) can I still convert for TV?
you can just just zoom and crop 16:9 HD footage in a 4:3 SD timline.
I am still going to run into trouble is the action is outside the frame. Will the TV expand my footage, or should I put black bars to be safe?
just mark off your lcd with 4:3 safe lines so you know you can crop it in post.
I can't see why anyone would shoot native 4:3 anymore these days unless they're delivering their footage in 4:3 only. Also, shooting 4:3 on a camera with native 16:9 sensors loses more resolution than if you were to crop the footage to 4:3 in post.
Shoot 16:9 -- you gain lots of added flexibility. |
Hi there
HD and HDV is native 16:9 ... so I can't imagine an HD projection going out in 4:3. On the Z1 you can only shoot HDV in 16:9. It will output SD 4:3 if you wish. So if you are delivering 4:3 SD you can shoot in HDV and downconvert in camera... I however would check out with the people using your stuff as I would be very surprised if they want HD in 4:3. Regards Gareth |
David if you edit with Vegas or Premiere Pro you can crop a 4x3 with keyframes and follow the action that way. I have used this even make it look like a two camera shoot in 4x3 SD if you like, though don't zoom in too much and your focus must be spot on in HDV.
Ron Evans |
It's like shooting HDV, capturing and cutting in HDV and down-converting. Better quality for a DV version, plus an HDV ready to rock and roll once the hi def DVD players drop.
heath |
