Capture Device not online.
Hello we just purchased this camera at work and I am unable to get Premeire pro to recognize the camera. I have looked through the settings and such but no luck. We have a multitude of other cameras of various quality and I have never had this problem before. Thanks for the help.
Does the windows device manager see it? It should see it in two places depending on the mode, for HDV you should see it in the Sound, Video etc... tab in the device manager as a AV/C tape device. Put the camera in DV mode and open a premier project with dv settings set the device controll to DV/iEEE1394 capture. Does it see it now? If so you have a menu option messed up on the camera. Like I said give me a call if you need to
see number above. |
Also when you make changes in the menu the I link cable must be unplugged and replugged or the Sony will not make the change. Sony has a problem here with this stuff. There are somethings that they didn't consider when setting this stuff up to work with windows. If the down convert is set to auto it freaks windows and premier out and the don't know what to do. Premier sees HDV and the wrong settings and Windows says hey it's a camera who cares what format it is.
well after going over it a couple of times i beleive that i have all the settings correct yet it not only wont capture but windows wont recognize the device. In the capture setting there is a pull down menu for device types and this camera is absent. Is there maybe a way to update that list? My coworker is going to try and reinstall premeire and see if that works.....thanks for all your help so far Jerry.
Do you have XP service pack 2 loaded on the machine? If not - no dice on the driver for the camera. PP doesn't have them it's a windows thing and SP2 is the only place I know to get them.
Well as I have been of no help at all to you --- One last shot in the dark. Do you havePP 1.5.1 installed? That may help also. Good luck.
| All times are GMT -6. The time now is 09:31 AM. |
