What tapes to buy for my z1?
hi
I will be recieving my z1 on Saturday!(woohoo) and need to buy some tapes. the Sony HDV ones are very expensive £15 a pop. I have read about NOT mixing tapes between brands? and about dropout which seems to be very random and irrespective of type or brand of tape. Does anyone have any advice about what tape I should buy and stick to? I have read DVCAM tape are good enough for HDV is that right? HELP! I need to buy some tapes before Saturday! Also anyideas where from? cheers mat |
tape for z1
Hi,
I have (2) z1U's and I use the recommended tape. Why go cheap on tape after having spent so much on the camera, at least that's my reasoning. Saying, that I have experienced a couple of bad GOP's in my first 10 hours of tape. I plan to use DV rack and tape together as a fail safe when I can. |
You don't say where you're from, but your post implies it could be the UK. If so then I'm not sure where the best place to buy things might be.
Personally I've been using the Sony Premium tapes in all my Sony cameras for several years and haven't had any problems. That's what I've been feeding my Z1 as well, although I haven't shot enough in HDV mode to definitively say they are the best choice. Here in the US you can find them for maybe $5 each in the large discount store chains (Best Buy, CompUSA, WalMart, Target, etc) or for even less by mail order. |
We're using Sony Premium tapes in our FX1 and Z1 with no problems...
Robin |
Hi
I a min the UK! As always -like most of you- I am trying to balance price with performance and wish to save money where i can.. I assume it I stick with Sony then if i use Sony Premium then sometimes use Sony HDV tapes I will not get clogging? |
Does anyone use the 80min Premium tape? If so are there any problems with them? Also what about the Sony Excellence?
cheers mat |
I assume this is true, but don't know for sure.
Matthew, it's helpful for others to know where you are, and this information should appear on all your posts. Please take a moment to click on the link "controls" on the top left of the page, then click on the Edit Profile link on the left. Now scroll down to where it says "additional information" and fill in your city/country. |
I have updated my profile! I feel purged of guilt...
And I have just noticed that I am now a regular crew member as I have hit 20 posts!! I feel great...
I am suspicious of expensive tapes, I don't think they're value for money in most situations. I've always used el cheapo panasonic stock and can't say they have ever let me down more than anything else would. If I want to archive stuff then I do use more expensive stock because in the long term they have a thicker skin and tend to tend age better. That is to me the only advantage of quality tape.
I've seen DVCAM tapes dropout, I've seen Beta tapes drop out (and these drop a lot) and so on. Dropout is a fact of life. You've got to consider that if you're paying £10 a tape because the manufacturer says they drop out less than a £3 tape, what they are actually saying is that they'll drop on average every three hours, as opposed to 1.5 hours for a cheapie. You do the accounting. I don't know how this all works for hdv footage, but again I cannot see why things should work that much differently, despite what some people say, HDv still uses the tape to store info in the same way. |
However, as a general rule, the reason better tape stock costs more, is because it does a better job, lasts longer on the shelf, and is more accurate in storage of signal/playback reproduction, and being shuttled. |
I recorded my brother's wedding and reception on the Sony PHDVM63DM Digital master tape, 7 hours of footage and not one dropped frame.
I haven't used any other tape in my camera. If the footage is that important, why risk it? |
I'm with Spot on this one. The most expensive tape is still the least expensive component in the production chain, so why skimp on it? Why would you put anything other than the best tape in a $3,000 camcorder. What is your video worth?
Especially when you consider single HDCAM tapes are 80.00....can't complain much about a 10.00 tape. But it's all relevant, I guess, because clients paying for HDV aren't paying for HDCAM.
