-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   Problems rewinding (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/472302-problems-rewinding.html)
Marcus Durham February 5th, 2010 10:55 AM
Problems rewinding
I was out using my faithful old Z1 yesterday as a B camera. On location I didn't have time to rewind the tapes when they reached the end as I usually do.
When I returned to the office I put each tape back in the camera to rewind ready for capture but the camera refused to rewind them giving an error along the lines of C31:C32 (from memory).
I popped the tapes into my PDX-10 and they rewound without fuss. Placed each tape back in the Z1 and all the footage was captured and the tapes rewound happily this time.
So what gives? I was shooting HDV onto Sony DVCAM stock (60 minute tapes). The Z1 doesn't have huge hours on it (a friend of mine has a Z1 with well over twice the hours).
Is it just a tape tension problem and I should have rewound there and then? Hard to do on a continuous shoot. Without the PDX10 happily rewinding the tapes I would have been stuck.
Anyone have any ideas?
Thanks.
Robin Davies-Rollinson February 6th, 2010 06:23 AM
Marcus,
found these error codes from a search on these fora:
C 04 00 Non-standard battery is used. Use the info LITHIUM battery.
C 21 00 Condensation. Remove the cassette, and insert it again after one hour.
C 22 00 Video head is dirty. Clean with the optional cleaning cassette.
C 31 10 LOAD direction. Loading does not complete within specified time Load the tape again, and perform operations from the beginning.
C 31 11 UNLOAD direction. Loading does not complete within specified time Load the tape again, and perform operations from the beginning.
C 31 20 T reel side tape slacking when unloading. Load the tape again, and perform operations from the beginning.
C 31 21 Winding S reel fault when counting the rest of tape. Load the tape again, and perform operations from the beginning.
C 31 22 T reel fault. Load the tape again, and perform operations from the beginning.
C 31 23 S reel fault. Load the tape again, and perform operations from the beginning.
C 31 24 T reel fault. Load the tape again, and perform operations from the beginning.
C 31 30 FG fault when starting capstan. Load the tape again, and perform operations from the beginning.
C 31 40 FG fault when starting drum. Load the tape again, and perform operations from the beginning.
C 31 42 FG fault during normal drum operations. Load the tape again, and perform operations from the beginning.
C 32 20 T reel side tape slacking when unloading. Remove the battery or power cable, connect, and perform operations from the beginning.
C 32 21 Winding S reel fault when counting the rest of tape. Remove the battery or power cable, connect, and perform operations from the beginning.
C 32 22 T reel fault. Remove the battery or power cable, connect, and perform operations from the beginning.
C 32 23 S reel fault. Remove the battery or power cable, connect, and perform operations from the beginning.
C 32 24 T reel fault. Remove the battery or power cable, connect, and perform operations from the beginning.
C 32 30 FG fault when starting capstan. Remove the battery or power cable, connect, and perform operations from the beginning.
C 32 40 FG fault when starting drum Remove the battery or power cable, connect, and perform operations from the beginning.
C 32 42 FG fault during normal drum operations Remove the battery or power cable, connect, and perform operations from the beginning.
E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
Marcus Durham February 6th, 2010 06:29 AM
Thanks. Will need to see if I can reproduce it.
