CF25 on Z1 for NTSC filmmakers - this is promising
I'm happy to report that cf25 seems to translate well if you're hoping to do an "in-camera" film-look type effect to mimic the 24p of the DVX...
I've done some early tests now with our cf25 footage that has lots of movement and the first interesting question that begs to be answered is "how are NTSC'ers hoping to use cf25 supposed to interpret the footage" ie. how should we "treat" it in our HDV-capable NLE's? Here's the dilemma - cf25 is a PAL mode with a "framerate" of 25 fps. It's not a true progressive mode of course - the Z1 is shooting all interlaced. You bring the cf25 footage into say Vegas 5d and it's interpreted as 1080 resolution, upperfield first, 25 fps. Now what? You have to obviously "convert" it. Just for kicks, I tried making a 25p 1080 SD DVD downconvert in Vegas but forgot to change the setting to "NTSC" so I got a flickering DVD... just like when you play a PAL DVD in an NTSC player - I'll try this again now after this post... Many here had talked about 25>24p via Final Cut etc. and living with the 4% audio shift or whatever... I tried this and have to admit the result in Vegas was not too promising - it looked very strobey and distracting, almost simulating cf24!!! Perhaps 50i to 24p will yield better results - but cf25 to 24p is not to my liking... Much more promising: cf25 to 1080 30p however was much "smoother" while still having that filmic cadence - this so far to me most closely has replicated 24p DVD's I made from 24p DVX footage... The biggest surprise to me in downconverting cf25 footage so far is that there is no appreciable resolution loss the way you have it in cf24... more of a surprise is that the downconvert looks very DVX-ish in terms of you'd never guess the Z1 was shooting interlaced - it looks very "progressive" Think DVX but higher resolution, less/no pixels in low-light... the cinematone/black stretch modes thrown on mimic the gamma/knee that DVX throws on in 24p mode very nicely... But still, the question remains is what sort of editing workflow ought an NTSC'er follow if he/she wants to get the most out of cf25? Say if you want to go to NTSC SD DVD out as a final product? Is there a definitive answer? I'll keep experimenting... Cheers! |
Mark, CF24 seems promising as well, if you ask me.
Yesterday I shot some CF24 footage on my Z1. I mean I was doing fast pans, and running and all the kind of stuff that make CF24 look ugly. Playing back on the camera, it looked horrible. The jitter steps, the jumping, all that stuff that people have complaineid about. I captured the footage....same problem. However, I decided to render, in Vegas 5.0d, a widescreen DV 24p (adding 2-3 pulldown) file....afterwards, that same ugly duckling footage became a swan. Totally progressive, nice fluid motion. Same as I am used to with DVX. Sad I have to go through that extra step, but happy it's in HiDef! So all the hooplah about how CF24 sucks...well....that may be true with those with a 200x magnifying glass and a mad scientist lab....but to me....a regular joe.....WOW! P.S. I feel you on the low-light part. I guess I over-reacted in my assesment. it's just from a guy who has been spoiled with the PD170 darkness powers, I expected the same or equal. - Shannon W. Rawls |
Mark, do you know exactly how Vegas was doing the 25 to 24 conversion?
Is it possible it was just dropping a frame to get to 24, and not being smart about it? In Final Cut, there's a function to do just this, and it slows the footage down. I have yet to test it, but there is absolutely no reason after using this fuction that CF25 footage would behave any differently than a 24fps timeline from DVX 24PA footage. Shannon, I'm going to go into EVS on Monday to see if I can burn some CF25 footage and bring into FCP...that is, if I have time to jump to the valley. |
I can't confirm how it's working it...
I'm not sure what's happening when Vegas re-renders out to the new frame rate - how it's converting 25 to 24... I think some of Sony Vegas software guys roam this place occasionally so perhaps they can answer...
I will add to Shannon's point that going through "intermediate" files is a necessary evil - I get the best results so far with cf25 when I create an intermediate 1080 25p HDV and THEN make the DVD compliant mpeg (ie. 720x480 progressive DVD)... of course, now there's different combinations to try out... the cineframe modes are interlaced so that's what's so confusing I think about this whole issue - are we supposed to try and go out to a "progressive" render to "unlock" the true potential of the cineframe modes? I've reviewed "PAL" vs. "NTSC" footage on the Z1 and really am starting to like the subtle, albeit very very slight enhanced 50i... Perhaps deinterlacing the 50i in Vegas to 25p 1080 (you create this template by selecting 1080 24p and changing frame rate) and then rendering out to SD DVD as a progressive will mimic what DVFilm is doing? It's too bad cineframe doesn't come with a set of instructions from Sony... I'm starting to guess that now since Z1 cf24 isn't any different from FX1: is it really a big boo boo or all we just missing something and not unlocking the true potential??? Not too likely since consensus is that cf24 definitely loses resolution...? |
Re: I can't confirm how it's working it...
<<<-- Originally posted by Mark Kubat : I'm not sure what's happening when Vegas re-renders out to the new frame rate - how it's converting 25 to 24... I think some of Sony Vegas software guys roam this place occasionally so perhaps they can answer... -->>>
Well if you're dropping 25fps CF25 into a 24fps timeline and it looks jumpy, it's safe to say it's not slowing down the 25fps footage to 24, it's just dropping frames to make things fit. That's exactly what would happen in FCP if you didn't use the conform 25 to 24 feature...it'd be a mess. I need some CF25 clips pronto! |
So at this point, is the general opinion if you want to shoot with the Z1 and have a chance of transferring it to film and being distibuted and all that--should you shoot at 50i and then convert to 24p in post? Is there a general agreement yet on the best shooting mode for film transfer?
I think in Vegas, when you drop your 25 fps CF25 footage into at 24p timeline you'd have to right-click it, go into properties and change the playback rate from 1.00 to .96 to account for the framerate change. You'd probably want to disable resample on the clip at that point too...
But wouldn't filming in CF25 mean a loss of resolution? If you want to keep the full 1080 is there a way to go?
I think CF25 is a wonderful way to go when you don't have the option (or time) to de-interlace 50i material. If your end product is SD, then absolutely CF25 is great. De-interlaced 50i with DV Filmmaker will give you better resolution if you can spare the time and disk space to use it.
I've been experimenting with various workflows for creating a nice (24fps ish) feel from this camera (Z1... soon to arrive) with these goals in mind... 1.) no image bleeding or blending from one frame to the next 2.) proper industry standard 3:2 cadence in any NTSC output I'm not concerned about the speed change of playing 25fps as 24fps, nor any damage done by altering the soundtracks pitch when changing speed. Based on all that, here's my current workflow I developed by working with the small handful of 50i .m2t's I've found on the web... (this is PC based, as this is my platform) 1.) Shoot 50i, 1/50th second. 2.)Capture and convert to Cineform codec. 3.)Edit realtime on a 50i timeline with Vegas (Premiere works as well). 4.)Export 50i uncompressed or 100% photojpeg QT from Vegas of final show. 5.)De-interlace to 2nd QT file with DVFilmmaker. 6.)Load this file in After Effects (perhaps QTPro can also alter the fps of a file and re-export... not sure)and interpret as 23.976. 7.)Export this combined with pitch shifted soundtrack. 8.) NTSC DVD or tape needed? burn out 720 by 480 DVD master as 23.98 or 29.97 by adding 3:2 pulldown at step 6. Now, the ONLY reason to use QT at anypoint is because DVFilmmaker can't work with the Cineform codec. This is a shame, as this codec is perfect for these intermediate files. Regards, Jim Arthurs |
<<<-- Originally posted by Jim Arthurs : 6.)Load this file in After Effects (perhaps QTPro can also alter the fps of a file and re-export... not sure)and interpret as 23.976. -->>>
it can't |
<<<-- Originally posted by Dylan Pank : <<<-- Originally posted by Jim Arthurs : 6.)Load this file in After Effects (perhaps QTPro can also alter the fps of a file and re-export... not sure)and interpret as 23.976. -->>>
it can't -->>> Darn, I didn't think so. That's a problem with "movie" files like QT and AVI. Unlike a sequence of images which you can assign ANY frame rate to, few apps will allow you to "tell" a QT of one frame rate to simply be another frame rate without repeating frames, etc. to do so. After Effects will play out a QT with whatever frame rate you tell it to and NOT repeat/drop frames on the timeline... Jim Arthurs |
If you have 25p material in a 24p project, Vegas can either drop frames, or blend frames, or you can slow down the footage for 1:1 frame mapping. Your choice.
///d@ Sony Media Software |
Hi Dennis... what is the proper setup for the footage properties to allow 1:1 frame mapping?
I've tried many combinations and the outputed movie still will drop frames... Thanks, Jim Arthurs |
<<<-- Originally posted by Dennis Adams :
... or you can slow down the footage for 1:1 frame mapping. Your choice. Sony Media Software -->>> Certainly the best option... Only the actors' blah-blah must be slow-down. A little bit and not enough to be noticed. But not the music. |
<<<-- Originally posted by Flax Johnson : <<<-- Originally posted by Dennis Adams :
... or you can slow down the footage for 1:1 frame mapping. Your choice. Sony Media Software -->>> Certainly the best option... Only the actors' blah-blah must be slow-down. A little bit and not enough to be noticed. The music remains at the same speed-->>> |
| All times are GMT -6. The time now is 04:38 AM. |
