-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   Z-1 Picture Profiles? (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/146466-z-1-picture-profiles.html)
Brian Henderson March 24th, 2009 12:26 AM
Are the Picture Profiles generally preset by the factory, or do people just customize them on their own?
On the V-1Us I've used the profiles were named for the looks they were supposed to have, Cinema, Sepia, Moonlight, etc. The ones on the Z I rented tonight are not labeled so I was trying to figure them out.
Also, does the Z-1 have a standard definition out even in HD? It seems like it should. I can probably find that in the manual.
Tom Hardwick March 24th, 2009 03:13 AM
The question doesn't make sense Brian. Maybe you mean does the Z1 down-convert HDV to SD and output it down Firewire? Yes.
Brian Henderson March 24th, 2009 08:23 AM
For example, the EX-3 has a monitor out that is SD, even though it is an HD camera. Thus you can use an SD monitor with it.
What about the picture profiles? Is there a "Cinema" one like on the V-1? What are the others?
Chris Hurd March 24th, 2009 08:33 AM
All HDV camcorders have an analog standard definition video output.
See the "sticky" thread http://www.dvinfo.net/conf/sony-hvr-...-settings.html for Picture Profile Settings... hope this helps,
