HVR-V1U vs. HV20 Low Light Performance?
Has anyone seen comparisons of the low light performance between the Sony HVR-V1U and the Canon HV20 Camcorders? (Since both have CMOS sensors).
I'm not talking manufacturers specs, because they can seldom be realistically compared. |
I haven't seen anything to compare, but you are talking about 2 cameras in completely different classes. The V1U has 3 CMOS chips while the HV20 has 1. I would be very suprised if the HV20 beat the V1U.
I realize that they are totally in different classes, but I am curious about how they compare on that one specification. |
I may be very wrong on this, but wouldn't a single CMOS chip that is 1/2.7" in size capture more light than 3 1/4" chips since the light in the V1U (and other 3 chip cameras) goes through the lens and the has to be split in a prism (thus loosing some brightness) to the 3 RGB chips?
The 3 sensors in cameras such as the V1 will give you brighter, more vivid and life-like colors, but not necessarily better low light performance. Now if the V1 had 3, 1/3 inch sensors, then I believe it would be better in low light than the HV20 or HC7. |
The light in the HV20 is split three ways with a color filter. Also, the overall light-gathering area of the V1 is .75" while the 1/2.7" chip is .37" at about half the size. Also, I have not seen footage that shows me that the HV20 is better than the V1 in low light. If it's two stops better than the V1, it will rival the PD170 and I do not believe that at all. Has anyone directly compared these two cameras in the same lighting conditions and location?
I found a German site that tests most of the cameras. Some can be understood, and the screen grabs of various tests are very good. You have to use the FX7 as a reference for the V1U.
http://www.camcorder-test.com/ I downloaded the low light (200 lux) screen grabs from both the HV20 and the FX7 and lightened them up to simulate post production correction; I then layered them with the XH-A1 shot. I tried to correct them so they were close to the XH-A1. I also layered the resolution test charts. I then viewed the images on a Samsung 56" 1080p TV. (Note that these are all 1440 x 1080 pixels, so I resampled them to 1920 x 1080 pixels) I was surprised that both the V1U and the FX7 looked better than the XH-A1 (at least to me), and were also visibly sharper on the test chart. The FX7 and the HV20 looked very close in performance. |
I know I was over exergerating the light performance difference. I thought that the V1 was a 7lux minimum. Still, the HV20 is about a 1/2 stop better. Of course the V1 is a better overall camera. That was not the question. The question pertained to better in low light. The HV20 is slightly better than the V1 in low light. |
FX7/V1 vs Canon XH-A1
".75"? The V1 doesn't have 2/3rd inch chips. .25" is the light gathering surface of the V1. You can't add the three chips because each chip has a job of gathering information for each color."
For the same reason the three 1/4" chips on the V1 can't be added up to 3/4", the HV20 can't consider it's entire surface area toward it's light-gathering capability. The HV20 and V1 both have their chips split up between the three colors so the HV20 doesn't have full 1/2.7" for each color. It doesn't matter how you divide the chip, the red and blue sensitivity will always be reduced by either a color filter or a beam splitter. Thanks for that link, Robert. The test is helpful and the HV20 and FX7 look to have similar abilities in low light. Unfortunately, the lighting is different for each camera so there is a big glare on the FX7 contrast chart. Regardless, it is fairly obvious that the two cameras are both in the same ballpark in low light. |
I also pointed out if you read my comment that if the V1 had 1/3 inch chips, it would beat the HV20 in low light, but that is not the case. Again I emphasize that I believe the V1 is a better camera overall than the HV20, but the HV20 is more light sensitive. That is a fact and not my opinion. |
Agreed. Three 1/4 sensors will not compare to one 1/2.7" sensor in light gathering abilities.
Each camera has their light-gathering surface divided by color. On third of the V1's chips are dedicated to each color and roughly one third of the HV20's chip is dedicated to each color. I say roughly because green likely has more area devoted to it than the red or blue. Regardless, the pixels won't be larger on the HV20 because three times as many need to be put on the same chip to get pixels the same size as one .25" V1 chip. You can't put larger pixels on the HV20 chip if it isn't three times the size of the V1's chips combined. It doesn't matter how you divide the total surface area.
I have yet to see any test or footage from the HV20 that looks brighter than the V1. It looks like a very nice camera for the money and form-factor, but it doesn't have larger pixels than any of the 3-chip HDV cameras. |
How can I explain this, so you understand? Let me try this: Sensors do not know color. The light is gathered on a .37 inch grid in the case of the HV20 and then passes through a color filter to produce the color image. Color suffers, but brightness does not, except for smaller pixels. The V1 has 3, .25 inch sensors that are used for each color. They are still gathered by sensors that do not know color, but since they are split by a prism, the light gathering surface is still .25 inch (all three are not gathered to one larger grid). The result is sharper, more vivid and more real colors, but not better light perfomance. The angle of the chips and larger pixels give the V1 an advantage, but remember the advance optics used to produce the color image hurts its low light capability much more than a color filter. The fact is if you put both cameras in a room with only 3 lux of light, the HV20 will produce an image; whereas, the V1 won't. From the factory, the V1 is rated at 4 lux. Sony is not going to underestimate the light capability of their camera. In fact, they're going to pad it. We're talking low light capability, and even with Sony's tricks, the V1 will not win this battle. By the way, I don't have a HV20, I have an HC7 which is my backup camera. The V1 is one of the cameras I'm considering for my main camera. If the V1 had 1/3 inch sensors, it would be an easy decision; the V1 would be my main camera. |
| All times are GMT -6. The time now is 11:18 AM. |
