Dropout issues?
I am just digitizing some footage from my V1U and it looks fabulous. I shoot in 1080i.
I have been noticing some dropouts (digital pixeling) more than I would expect. Many times it was when the camera was moving suddenly and therefore the footage was not important, but now I am seeing more of it. I was digitizing some footage of a man ice skating when it happened at the worst possible moment...it was a large wide digital artifact that ruined the shot. Is this something you HDV guys live with? Or is this unique to my camera? I have shot SD with our 2 Sony DSR-250's for years and have never seen this amount of dropouts (or whatever they are called) and I'm becoming alarmed. Does anyone have any insights? Is there something I am possibly doing wrong? On one dropout I noticed last week....I just re-digitized the clip and it wasn't on the tape the second time around. But this latest spot has been redigi'd 4 times now, and it stays in the same spot and has ruined the shot. Do I have a lemon? |
What sort of tape do you use?
I don't have enough hours on my V1 to say if this camera is prone to dropouts. I have shot HUNDREDS of hours of footage on my FX1 and can only say I've seen maybe 5 or 6 dropouts. I use Panasonic Master tapes (the white ones) and sometimes I use the regular Panasonic tapes. I try to avoid mixing brands.
If you are seeing that many, I suspect you either have some bad tape stock or there is something wrong with the camera. |
Sony Digital Master HDV 63 mins. PVHDM-63DM
this is VERY disappointing. I wonder if anyone else has heard of this? |
When recording long GOP, where only every 15th frame is real, there is a some risk of a catastrophic dropout. If you're using Final Cut Pro you might try Digital Heaven's DH_Dropout Plugin. I use it on Betacam dropouts and it works quite well.
http://www.digital-heaven.co.uk/fcpl...dh_dropout.php So far I've only shot some test footage in HDV on my V1U and haven't noticed any dropouts. Time will tell. |
I have shot about 3 hours on 3 tapes. On the very first tape I shot, using the supplied Sony Master tape that was in the box, I experienced 1 dropout about 5 minutes into the tape, which I think was the first dropout in HDV (I had been using a Sony HC1) I'd ever experienced. It manifested itself as a 'skip' in a long pan I was doing, as if time had just been cut out. I had been using Panasonic masters previously but I didn't have one of those tapes for the first shoot and so used the supplied Sony master tape. Later tapes I used the Panasonic Master tapes DVMQ-63, and haven't experienced a dropout since.
Perhaps it is the Sony tapes, I had never used them before and they are about 3 times the cost of the Panasonic Masters so I'm going to continue to use the Panasonic tapes unless I have problems. Regards, -Keith |
On *any* brand new camcorder, as soon as it comes out of the box, you'll want to run a head-cleaning cassette for a few seconds before putting in that first tape. This practice solves 95% of all dropout issues associated with new camcorders.
This issue is *not* limited to any one particular make or model of DV or HDV camcorder. |
I've shot over 8 hours and the drop-outs are typical for HDV. I use only Sony and JVC DV/HDV tapes. I nevr use Panasonic tapes.
I feel the Sony HDV tape is worth the price. |
I have had good results over the years with Sony tapes. |
I shot over 50 tapes over 2006, and experienced drop outs on every tape, on every shoot. I just take it and live with it.. one reason to shoot a safety for every take.
Z1U and FX1. |
Something's amiss, Robert. You should not be experiencing that high a number of dropouts.
As for the original poster...you said the (latest) problem occurred when shooting an ice skater. How cold was the camera? I have had small Sony camcorders start to glitch in various ways in cold weather (below 30 deg F). The colder the camera, the worse the operation. |
I have been shooting with a Z1 for over a year and only ever had one drop-out.
I've barely shot 10 hours of footage with the V1 and already had 3 or 4 drop-outs. On the expensive Pro tapes, too. |
Interestingly the only time I've had droputs was with the Sony HDV tape. Once I went back to regular Sony mini-DV tapes all was fine. Go figure.
I shoot on Maxell tape the cheapest I can find and have had no problems. I have only shot a few hours from my V1 but have had my hc1 for over a year with no problem. I can only think of one dropout on my hc1 and that was the first tape I ran thru it. I am probably just lucky. I will continue to use the cheep tape unless there is a problem. I just looked and I have over 400 hours of dv on Mexell tape.
| All times are GMT -6. The time now is 11:18 PM. |
