stereo for V1U?
I mostly plan to use the XLR inputs to do traditional mono recording of sound. Input 1 for interview sound, input 2 for b-roll ambient sound.
But I'd also like the option to record stereo sound for some small film-type projects. Does the V1 allow that like the Z1? I know the V1 doesn't have an onboard stereo mic. Can I buy one (such as the audio technica at822) and make my own stereo sound? Anyone know? Thanks. |
you can purchase any number of stereo mics from many manufacturers, and connect them/mount them to the V1U
does the V1 have 4 inputs?
Douglas, thanks for the reply... does the V1U have 4 inputs?
xlr 1, xlr 2 and input 3 and 4 for stereo L and stereo R? |
Michael,
Let's say I just want to use the built in shotgun mono mic for ambient sound. Will it give me L+R when I play it back? Thanks, Sal |
As Michael mentioned, the cam is two channel. The HDV spec *does* allow for four channels of 32k/12b audio, similar to DV, but thankfully, no one is using it. It's terrible in DVland, it would be terribly worse in MPEG audio format with the lower bitrate/sample rate.
As far as L+R, it'll give you two channels of mono audio if you switch the audio to do so. Or, you can run the mono shotgun on channel one, and connect a second mono mic to channel two. Or, you can purchase a stereo mic as you asked above, and connect the two outputs from the stereo mic to channels one/two. |
So use an on camera shotgun (mono mic), and a wireless for the other source, either on an individual (using lav mic), taking a direct feed from a sound board fed diretly into your free channel (either hard cabled or wireless), or use wireless mic with transmitter (miccing another sound source, like talent with boomed mic or recording from a monitor speaker) sent to you camera. |
Sound
Yea I will mostly use the mono shotgun for ambient noise and keep the talent mic (when not using it on talent) on the camera or on my belt.
as for wireless, I have found that the lectrosonics 100 series is pretty reliable but I used it on a muc bigger camera with more room for mounting the receiver. As for microphones...I own an Electro Voice 635A mic and wonder if it's worth it to slightly upgrade to the EV RE50B (the nice looking black one). My 635A sounds great but it's silver. I know, I know..no big deal. I appreciate all the knowledge on this board. |
RE 50 adds more wind protection, shock mounting, and heft. Generally, it deals with handling noise much better than a 635. Proven in combat, hurricanes & etc. You could always take a black sharpie to your 635 :) It does sound the same outside of a really strong breeze. |
Stereo Mic for V1U
I have done some research and found the Edirol CS50 stereo shotgun mic to be the same size as the supplied mic and cheaper than the AT stereo mic. Also found the Y connector:
Mic:http://www.edirol.com/products/cs50/cs50.html Y connector:http://www.soundprofessionals.com/cg...-XLRF5-XLRM3-2 |
Additionally, let's say you use a lavalier plus the on camera mic. With a L/R mic you'll be recording either L or R so you won't be recording directly in front of the camera. With M-S you just keep M plugged into channel 1 and then the lavalier into channel 2. The CS50 doesn't seem like it allows you to output an un-matrixed signal, so it would have the same problem as a L/R mic in this scenario. |
microphones
to all, thanks for the wonderful information.
I am somewhat of a mic junkie so any recommendations are totally welcome. I notice that the pro TV crews almost always use the RE50B in the field. While I won't necessarily copy what I see the pro crews use, to a certain extent they buy what works and what holds up. My buddy who is an ENG photog, works at a TV station that uses Lectrosonics wireless, EV RE50B, the Anton Bauer on-camera light. etc etc. (As an aside, his station uses the Panasonic DVC-PRO50 that uses only p2 cards and shoot 16:9 switchable with 4:3). Thanks again. Now I can't wait for the V1 to be released! |
Edirol Connecting cable
I know the camera does come with a 5 pin XLR to two 3 pin XLR connectors but 2m (6 feet) - wouldn't that be a bit unwieldy for a camera mount ? The connector set I researched can be ordered in 12" length.
http://www.bhphotovideo.com/bnh/cont...ist&sku=174982 WHAT IS THE DIAMETER AND LENGTH OF THE V1's BUNDLED MIC? Depending on the answer, here is an alternative Sony mic: http://www.soundprofessionals.com/cg.../item/SP-PSM-3 Even cheaper AT: http://www.soundprofessionals.com/cg.../item/AT-PRO24 This link gets you to a Y adaptor for such mics: http://www.soundprofessionals.com/cg...mplate=reviews The standard length is 8-inch, but you can order shorter lengths. |
| All times are GMT -6. The time now is 09:44 AM. |
