Ninja
Hi, this thread is from the canon 7D forum, and its made clear that HDSLRs dont output a true HD picture out of their HDMI out (stupid I know), but what about the Sony V1, which as we know does output a full HD real-time uncompressed signal over HDMI (ie prior to being compressed to HDV as it gets to tape?) Would be interested if anyone knows anything more about this! cheers |
The HDMI out from the V1U is 4:2:2 uncompress HD. I think it's 1920x1080, but can't find a reference to confirm that. It's at lease 1440x1080.
I can confirm that the V1U HDMI port outputs a full resolution signal directly from the sensor block, before the content would pass through the compression stages for writing to tape as HDV.
On that basis, you will have the full 1080 resolution. Andrew |
Has anyone on here actually seen and worked with uncompressed footage from the V1? I too am interested in extending the lifecycle of my V1, but I don't want to start grasping at straws and hoping for miracles. I mean it is not going to turn it into an EX1 or anything like that is it!?
Cheers, Simon |
Well the EX1 has many additional factors that contribute to excellent footage, eg, focusing is easier, probably a better lens resolution, better compression scheme etc But even EX1 footage is compressed, though not as bad as HDV! That's why the ninja is exciting because it could take the uncompressed output before HDV compression and convert to Apple Prores. (So only useful for Final Cut users).
This surely must provide advantages for improved resolution, color correction and chroma-keying compared to taking the HDV or XDCAM footage and either editing directly or converting to Prores first b4 editing? Frankly I find it hard to believe that a 2.5" drive is going to be able to capture uncompressed video as the Ninja purports to do! |
If the Ninja works as advertised, yes, it should be far superior to HDV and XDCAM EX for keying and grading, really any efx work. I've got a lot of chromakeying coming up, would love to get into a 4:2:2 codec for shooting. I'd think that transcoding HDV to Prores422 or HQ helps with multiple generations of efx and grading, but the chroma information has already been crunched, and there wouldn't be much improvement to chromakeying. Even where transcoding helps, it's not going to add chroma resolution, it's just not going to degrade as badly. Anybody see the Ninja at NAB or IBC? |
I have two V1s with a Nanoflash. I bought the NF to extend the life of my V1s. I really wanted to work with higher quality footage but I could not decide which new camera I wanted to buy. Then Canon came out with the new camera that records to mpeg 2 at 50 mbs. Well that is where the NF starts and the quality settings go up from there. So that really pushed me toward the NF.
I will up grade my camera when I find the right one and even then I will probably record to the NF. The quality upgrade from HDV is beautiful. I liked the V1 when it was HDV but now I have a reason to hold on to it. I can shoot great footage while I look at the new cams coming out. I do not know anything about the Ninja, but the concept is the same. I do know I do not trust Ninjas they are sneaky. |
Hi Ron I've agonised over purchasing a Nano for awhile now. Did it improve the quality of the footage captured from the V1 dramatically enough to justify buying it? I mean selling the V1 + cost of a Nano is not that much different than just buying an EX1. |
Simon, I was using the same thought process. I tried to sell both my V1s with no luck. No one even made an offer.
I know that when I get an EX or what ever I get I will probably still want to use the Nanoflash nothing else records to such a high bit rate. I just bought the Nano first. And yes the video is better but you still need to light if it is a low light situation. But for low light and shallow depth of field I have a Canon 7d. |
Ron, if you need to sell the V1s then talk with people who shoot video of sports matches. They'd much rather have 20x optical zoom than settle for 12x only with the EX1 etc models.
Andrew |
update on ninja
The latest web gossip seems to indicate the Ninja may be out during December. Here are 2 posts
Atomos Ninja Compression Workflow & Benefits- 6 to 1 Compression: | Cinescopophilia Atmos Ninja For a specific segment of customers (HDV or AVCHD or DSLR with HDMI out and who dont have budget for Nano or KiPro prices, and use Prores) this product is surely a godsend for us V1 users? And so much SMALLER than the Nano or KiPro. |
And it uses the standard Sony camera batteries, too.
Andrew |
| All times are GMT -6. The time now is 11:17 AM. |
