Image noise in the V1
Something that bothers me is that even if you are shooting outdoors in the bright light, you still get noticeable noise from the Sony V1. An associate of mine is also disappointed with the same issue.
The kicker is that this image noise will be stealing "bitrate budget" from the content that you want to have recorded within the comparatively limited data rate of the HDV format. In a way, I'm not entirely sure how they decided to release this camera as it is. Is it me, or do you need to add another zero to the price before you have a camera that can record stable tones in proper levels of lighting (courtesy of a larger sensor size). I'm happily open to being educated on this. What do you guys recommend for minimising image noise? Andrew |
Thanks. I'll adjust this and see how it makes a difference.
... just as soon as I can locate where it is in the camera menus ... :-o Andrew |
Decrease sharpness a bit as said. I found sharpness 6 to bring a very nice improvement to FX7 picture, and found unnecessary to decrease it further - unless that's your personal preference naturally or you're after soft look / film look.
And if I recall correctly, early "marching ants" discussions in the forum showed that recommended sharpness settings would be different between FX7 interlaced video and V1 progressive (if you're going after progressive), like going down to 5 or 3 maybe, because of the different impacts of aliasing. So make sure to check the early V1 threads for your V1 appropriate sharpness settings. |
I had a friend complain that his Z1 produced noisy pictures. Turned out he'd locked down everything but the gain, and of course that was constantly on the hunt (invisibly as it's not shown in the v'finder if not locked). It's a wild thought that might help?
| All times are GMT -6. The time now is 10:44 AM. |
