-   Sony HVR-V1 / HDR-FX7 (https://www.dvinfo.net/forum/sony-hvr-v1-hdr-fx7/)
-   -   Print to Tape/Camera? (https://www.dvinfo.net/forum/sony-hvr-v1-hdr-fx7/137285-print-tape-camera.html)
James J. Lee November 5th, 2008 11:55 PM
Do any of you have experience with printing from the NLE back to the camera? I've tried to follow all the instructions in the destruction manual and though the camera appears to be controlled via VTR and begins recordering, I see nothing but a blue screen on cam and don't see anything on the tape. Gotta have a setting wrong but it seems I've tried them all. I'm just trying to print DV footage back to the camera. Should be easy right??? Any help?? Thanks, JLee
Leslie Wand November 6th, 2008 03:28 AM
camera?
software?
format? (sd/hdv)
Max Volki November 6th, 2008 05:13 AM
James
you dont give much info
if it ist an V1 and you say DV, then:
Firewire connection OK?
Set the Camera to DVCAM/DV, not HDV or Auto (!!)
Use a tape which is precoded, at least the first few minutes
set the startpoint, in VTR mode, at a precoded point, and leave it "on"
volki
James J. Lee November 6th, 2008 07:54 AM
V1u
I'm using a V1u. Footage was originally shot in HD 1080i60 but captured in Final Cut Express as DV-NTSC anamorphic. Now I'm trying to "Print to Video." Everything seems to work as it should EXCEPT that I have a nothing but blue screen on the V1 with the record light showing?
Leslie Wand November 6th, 2008 05:08 PM
don't use fcp - but i can tell you that you can't ptt UNLESS the file meets the exact HDV specs. ie. the same as the original recording. had endless problems when trying to ppt from vegas only to discover that the only way was to render the file without 'smartrender' to the default m2t hdv format....
leslie
edit: sorry - what exactly are you trying to ptt? dv / hdv / anam?
Hugh Mobley November 6th, 2008 08:28 PM
If you invest in Cineform, I use NEO HDV, it is absolutely effortless, after you edit, to go back to tape from the NLE, In my case Vegas 8. Never could get Vegas to do it.All my stuff I want to keep on tape I render out to m2t and put it back on tape. It just works
James J. Lee November 6th, 2008 09:29 PM
I don't get it..
Well I guess I'm not the only one that's had the problem but I still don't get it. This footage was shot in HDV on the V1u, then down converted to SD on capture. So, I don't understand why the camera would fail to receive the SD timeline footage. At this point, isn't it just a mini-DV deck? FCE's PPT feature seems to be functioning properly and seems the camera deck is the hold-up. But, I've set the V1u to record SD and tried an number combo of settings and can't seem to get there from here. I assumed I was just missing a setting or had a step out of order.
Greg Laves November 6th, 2008 09:35 PM
I have CS3 and I have often taken HDV back to the V1 with no problem. I never tried DV.
James J. Lee November 6th, 2008 09:45 PM
HDV works
Yep, HDV Ptt seems to work fine. Unfortunately, I have a post pro editor working in Avid(pc) that can NOT work with my AIC 108060i Quicktime files and doesn't have a HDV deck so has asked that I just send a DV tape version. Unfortunately, FCE doesn't have many options for HDV codecs. So, if I can't print to tape, does anyone know of a codec conversion software that Avid recognizes. Getting this HDV (or even an SD tape) into his Avid workflow is more problematic than I ever expected.
Hugh Mobley November 6th, 2008 09:58 PM
another thing, it will not go back to tape if it does not fit the m2t template, it has to go back the same as it was captured.
Justin Zimmerman November 6th, 2008 11:21 PM
it was impossible to print back to tape until the newest version of FCP Studio was released.
this might be a problem with your NLE.
i've never down converted to SD so I can't help you there, nor have i used FCP Express. I can tell you that with Studio 2 it is now an effortless process to export / print to video in FCP Studio 2 in HD using the Pro Res CODEC.
good luck.
Justin Zimmerman November 6th, 2008 11:22 PM
can his AVID read the Pro Res CODEC? the newest version of Quicktime had an immediate update.
time for a MAC editor...
James J. Lee November 7th, 2008 10:19 AM
ProRes
Justin - That's a good question. Have done some searching on Avid and see no reference to ProRes. Haven't upgraded quicktime pro as I'm always reluctant to do so without first checking any compatibility issues. Wonder if I'd still have issues coming from a Mac to PC. Right now I'm looking for an OH based (if possible) PP house that uses Avid & has HDV capture abilities. Need to find the right place to post the question here.
Justin Zimmerman November 7th, 2008 11:18 AM
i went to school at OSU and OU - i know Marietta well.
sadly for you i'm out in Oregon and 100% FCP Studio!
hope Marietta is treating you well.
clink on my site if you'd like an intro to some of my films. several were shot in Ohio!
jcz
bricker-down productions
Charles Newcomb November 7th, 2008 09:46 PM
If you downconverted to SD, then you need to change your on-camera menu so it's seeing DVCam from your NLE, not HDV.
