Stuck with one mic, wanna swap?
Well, here's where I am with my v1. I had been tacking one of my AT835bs on it with a shock mount, and I was happy with the pickup. But when I put the camera on my steadicam pilot, I have significant balance problems, and the length of the AT835b shows in my light as a shadow. My current set up is here http://droptodesign.com/test/pilot/DSC_0042.jpg
So since balance and the light is an issue, I was thinking of just swapping my V1u mic out with something, the same length, same diameter, but would have a better pickup. I'm not that much of an audio guru, so I wanted to request some opinions. I've read most of the microphone threads in the V1u. And I don't want to have to mortgage my house for a microphone, but I'm willing to spend between 300 and 500 or so. |
I have read countless post in the dvinfo audio forum and watched Ty Ford's excellent mic demo. I am convinced from reading, listening, and use in the field that a decent "short shotgun" supercardioid is the type of mic that most low-budget shooters need. A true long shotgun is not at all the magic bullet type of mic that people on a budget need. The shotgun mic has way too much low end reverberation to ever be the ideal mic indoors so it is really handicapped for filling the role as an all-purpose microphone. Also, you have experienced another drawback to a long shotgun mic in that the AT835b is 14.5 inches long! That thing could be used in an escrima match.
From all the mic sound samples I have listened to and the recommendations I have read, there are two good mics that should fit your description and budget. I'm sure others will chime in, but for now take a look at the Rode NTG-1 at ~8" and $250 or the AT4073a at ~9" and $550. I have used the AT4073a that a friend owns and it was the first mic that ever left a significant impression on me. I have listened to sound samples and the NTG-1 seems to be in the same ballpark and also has many favorable reviews from Dvinfo.net members. |
Yep, you hit the nail on the head. I've worried about injuries with the AT835. And I've been reading tonite and still was confused. Thanks for the input, I needed it.
Hey Marcus
I think I'll roll with that NG 1, I like the size. I get weirded out just having one microphone on that pilot, I think I can mount the NG just over top of the stock microphone, so it shouldn't be that huge of a balance issue.
Thanks for the recommendation. Wanna buy an AT835b? Gee, not a lot of difference in price between the NG 1 and 2..hmmm |
K6
interchangeable heads and great pick up. how about the K6 series from Sekonic. love em.
The Rode NTG-2 simply adds battery operation ability to the same NTG-1. All this will do for you is add the extra lenght for a battery compartment. You have phantom power on the V1 so you don't need battery operation.
Yeah, length is what I'm staying away from. I ordered the NG1, hehe, it can't be worse than the stock mic
Let us know how the NTG-1 works along with the V1. I also need a mic and have come close to getting one of the Rodes. I would like to know if the output levels in various environments work smoothly with the V1 inputs. For instance, does the NTG-1 pick up voices at a decent level from two feet away? The stock mic is okay at high pressure levels, but regular speech is out of the question. On the other end, is the NTG-1 appropriate for high sound pressure levels like those encountered at a musical performance.
Sure Marcus, If by chance my old brain doesn't remember, just send me a reminder. I have a gig this weekend and will be stacking the NG-1 along side the stock mic.
Thanks again for your help. |
I would have heartily recommended the Sanken CS-1, a short shotgun that compares with the 416... Mind-boggling steadicam setup you have there! |
Hehe, yeah Matt. Since we do multicam weddings, I had to figure out a pilot settup that I can switch to on the fly. For instance, we'll have the steadicam setup, but if we want to switch to the tripod, I need to be able to do it on the fly, without pulling a screwdriver out. I had to have that quick release adapter fashioned by a metal shop. About the Sanken CS-1, I think I read somewhere (over my days of reading) about that micrphone. My goal in getting the Rode is to get the biggest bank for my buck for 'on the fly' audio. I have other mechanisms for the rest of my audio. Thanks again for the info though. |
