Fire wire issue in Hd1000e
Hi all. I usually capture through a 1394 contoller to PPcs4 in windows 7. Now the program does not recognise the camera. I tried using Pinnacle 12 and the same result. I tried using different fire wire cables, another card bus and on 3 computers with different operating systems. The camera shows that it is connected to the cable (fire wire/i link). All drivers for the 1394 controller are up to date, could I have missed something, perhaps in the settings. I,m not too pleased with the thought of sending it to Sony here in Spain.
Regards Ian |
One possible setting to check: the format selection in the camera menu to be sure that it matches the footage on the tape. If you shot in HDV, is the menu set to DV or Auto? Or, if you shot DV, is the menu set to HDV or auto? If you have it set to "auto," try switching the setting to the specific format you shot, or vice versa. When I was using CS4, my system sometimes would talk to Sony camcorders set to Auto and sometimes would require me to switch.
Thanks Jay (love Montana by the way)
I double checked all of the settings, they are fine. I only ever recorded and captured in HDV. I have however viewed a few tapes through the camera which were shot on my PD170 (dv). I cannot see that affecting the HDV capture? I know the computer, 1394 cardbus and cable are OK, it can only be a setting or a blown ilink port. I use the camera myself and take care in connecting to the computer so that seems unlikely. One other point (I cannot see how it can change the settings), before this capture attempt I for the first time plugged in a USB cable to copy over some stills? |
No, the USB connection wouldn't likely be the issue.
If there have been no changes to either the settings in the cam or to your PC -- including Windows updates -- then it could possibly be a bad port on the cam. Have you ever connected the cam to the PC while either was powered on? Can you confirm that VCR HDV/DV is set to HDV, that i.Link Conv is OFF, and your LCD during playback reads HDV1080i on the upper left and both i.Link and HDV Out on the upper right? |
Hi Adam
No I have been very carefull on that regard. Typically I bought the camera in South Africa, live in Spain and have to work in morocco in a couple of weeks time. Sony Spain will take at least 2 months to sort it out. I will try a few more things before I send it for repair. My next cam. will be solid state even though the HD1000 for 6 months did it's job well. Regards ian |
Again, can you confirm the settings and displays above?
HDV is set with the 1080i in the left top. This is the strange part, when I set Video out in the menu (apart from Down convert), OK it and leave the menu, the right hand side reads HDV in ilink. It goes back to down convert? At least were on the right track, I will double check all settings, change tape etc and reply this morning. Thanks Adam
John |
Here are my settings;
VCR HDV/DV set to HDV Component set to 1080i/576i Down Convert set to i.link OFF On the camera screen it reads HDV in i.link not out? Any thoughts |
With the cam in PLAY/EDIT mode, when connected to a PC via FW and while playing back, the upper right should definitely say HDV Out next to the i.link logo. It will say HDV In when you are not playing back.
What happens when you push Play? If the screen does not switch to HDV Out when properly connected and playing, you may have an issue with the cam. Another thought: you are absolutely certain that both Capture and Device Control settings in Premiere are set to HDV, as well as all the Project Settings and Presets? There have been some reports of FW issues under Win7, but I'm not sure how credible they are and if it used to work but no longer does, then it's likely another issue. Again, are you sure there have been no updates to Windows or anything else? |
Adam the PP pre-sets are correct, I have tried on another editing program as well.
Yes if I press play the HDV out i.link is on. PP still says 'offline' One point. This camera was never listed in the 'options' window for a device. I normally use Alternate 1. This should have no change now. All the settings are correct. I did try on a Vista machine with Pinnacle and another with PP2 using XP. |
Then I'm stumped.
I will play around a bit, thanks for your input.
Regards Ian |
Please let us know if you get it sorted out. This is a curious one.
