-   Sony HVR-HD1000 (https://www.dvinfo.net/forum/sony-hvr-hd1000/)
-   -   Is Mic input supply +5v bias? Question for DIY Project (https://www.dvinfo.net/forum/sony-hvr-hd1000/129188-mic-input-supply-5v-bias-question-diy-project.html)
Foucault Martial September 2nd, 2008 04:56 AM
Hi,
Is someone knows if the HVR-HD1000 supply +5v bias for condencer mics ?
Ville Honkonen September 7th, 2008 11:01 AM
I have beachtek xlr adapter, i have sonyhd1000 own mic and a sony PWD530 mic, when i try to connect pwd530 mic to the xlr adapter it not work. but when i connect a wireless mic to beachtek it work's
so the default sonyhd1000 mic will work with battery?! but where is it..
Foucault Martial September 7th, 2008 11:38 AM
------------ when i try to connect pwd530 mic to the xlr adapter it not work
I think this mic need phantom power
------------ so the default sonyhd1000 mic will work with battery?
I done some test on the HD1000's minijack plug, and it supply +3v.
Ville Honkonen September 7th, 2008 01:36 PM
The hd1000 default mic is not a phantom mic ?
Foucault Martial September 7th, 2008 03:54 PM
No, it's not a phantom power mic, also it has only a minijack plug.
Ed Sharpe December 16th, 2008 01:47 AM
the microphone that comes with cam...
ok so what is the bias.... and how good a microphone is this?... and what other microphones run off this cam without using batteries.
thinking of getting this or the panasonic that records to sd cards that is a sholder mount.
Foucault Martial December 16th, 2008 03:00 AM
I don't understand well ...
Ed, could you explain a little bit more your post ...
Ed Sharpe December 16th, 2008 03:25 AM
please re read I cleaned the spelling up!
Foucault Martial December 16th, 2008 03:48 AM
Ok,
Maybe someone can explain better than me but I'll try my best.
So, the Bias is only the fixed +3V on the Mic (Plug in Power) used for the original camcorder mic alim.
To use another mic you can choice the mic you want.
- Some needs Phantom Power (not provide on this camcorder), it's necessary to use external unit (ex : Beachtek DXA6)
- some needs internal battery (ex : Rode NTG2)
- Some works alone (ex : Shure SM58)
The last thing is to convert from balanced to unbalanced for this you can use a Beachtek DXA2s.
thinking of getting this or the panasonic...
Which Panasonic you speak about ?
Ed Sharpe December 16th, 2008 04:07 AM
sony sholder vs pansonic sholder camera I need to decide which at BH Photo
The panasonic is the... AG-HMC70 the sony is the Sony HVR-HD1000
Guess I need to decide in the next few hours... yes examine the audio on the panasonic also.
The panasonic records to dshc cards and has xlrs but no focus ring. I wonder also which optical image stab, is better? sony's or panasonic?
Ed Sharpe December 16th, 2008 05:03 AM
for comparison panny manual... ftp://ftp.panasonic.com/pub/Panasonic........
ftp://ftp.panasonic.com/pub/Panasoni...G-HMC70_OI.pdf
Foucault Martial December 16th, 2008 05:08 AM
I'm sure you will do the best choice for your needs.
HVR- HD1000 is HDV
AG-HMC70 is AVCHD
They are not the same HDV vs AVCHD.
Comparaison test (not complet)
Good choice, and give us news
Ed Sharpe December 16th, 2008 06:35 AM
the two cameras....
It is a hard choice between these cameras... I wonder which is better at lower light.
I probaby need to spend about 8k for a camera to do all I want plus be light sensitive but.... that is more than I have to spend!
I wonder if sony vegas 8 handles the avchd format well too... I know it will work well with hdv.
HVR- HD1000 is HDV
AG-HMC70 is AVCHD
Ed Sharpe December 16th, 2008 07:08 AM
sony compact flash units...
a pity the ones that fits a couple of the other units will not work with this... I wonder how it interfaces.....
the sony looks a little nasty at 12 lux in this comparison table... I wish it showed what the payy looked like...
Ed Sharpe December 16th, 2008 07:24 AM
the xlrs on the panny
the xlrs on the panny this is great.
i am trying to figure though just how good the 13 mbps record rate is on the avchd
