-   Sony HVR-A1 and HDR-HC Series (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/)
-   -   How long charge battery? (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/99008-how-long-charge-battery.html)
Kevin Carter July 15th, 2007 09:05 PM
It seems to be taking forever to charge my battery. hdr-hc3. Wondering what others find
Kevin Carter July 22nd, 2007 01:40 PM
ok guys, help me out here.
I got some progress. I got two cameras, to AC adapers, and on one bank, the AC to camera charged battery #2 fine.
On other bank, AC and camera 1 can't seem to charge battery 1. the AC, and camera get hot, and the battery is still at only 1/4. I don't know the culprit though, anyone have any ideas? thanks.
Jeff DeMaagd July 22nd, 2007 01:45 PM
Did you try using battery 1 with camera 2 yet? Or battery 2 with camera 1?
Was battery 1 left discharged/ dead and then unused and uncharged for weeks at a time?
Kevin Carter July 22nd, 2007 04:36 PM
thanks Jeff, well I'm going to do a bunch of test shortly, using variations between my batteries and ac adapter and two cameras. This battery was at 1/4 full for several weeks.
I'm also trying to figure out best way to drain other batteries to test this.
Jeff DeMaagd July 22nd, 2007 05:36 PM
I think you have it, you need do need to try several combinations to narrow down what is causing the problem. Try to change only one variable at a time.
I don't know of a good way to drain batteries. I think the best may be to just record on a dummy tape until the battery dies.
The reason why I asked if the battery was left dead for a while is because I read that Lithium batteries can be damaged if left like that too long, and they can get into a "deep discharge" state where they take a very long time to recharge.
Adam Gold July 22nd, 2007 10:09 PM
The HC3 manual says to turn A. SHUT OFF on the STANDARD SET menu to NEVER and leave the cam in record standby mode. The heads will spin down after a few minutes but everything else stays alive to drain the battery. Page 116.
Guest July 26th, 2007 04:57 PM
Ah, this is interesting... I've been meaning to ask -
I'm using an NP-QM91D battery with my A1E, and I've used it on my old PC101E before;
When I first bought it, it could provide about 550 minutes shooting time on the PC101. After a while it would only charge up to 300 minutes - and similarly now on the A1, it is apparently charging, but it doesn't seem to be getting very far...
So could the cause of this be because it's been left undrained for a long period of time? I thought Li-Ion didn't have a memory effect?
James Harring July 26th, 2007 05:07 PM
Battery's probably checked into the Old Age home
Just my opinion.
I manage a fleet of laptops w/ LiOn batts. They last 8-24 months. Some make it to 36 months, but none recharge to 100% after 18-24 months. Most hit half-life around 12-15 months - only lasting half as long as when new.
If you REALLY want to know more, here's a great site for you.
http://www.batteryuniversity.com/partone-5.htm
One good strategy is to buy batts over time and use a marker to indicate month/year when placed into service. We do this with our replacement batts, so we can go back for warranty service, if still in warranty.
By the way, i am refering to running time, not the LED meter when I mention recharge percent.
Guest July 26th, 2007 05:44 PM
Originally Posted by James Harring (Post 719216)
Just my opinion.
Thanks for that... hmm, yeah I guess mine has just worn down to 50% then. Which is a shame considering it started off as advertised - it gave 9 hours life. Oh well, 4 hours should suffice... I'll probably buy another one, they're dead cheap now on eBay, around £15 cheapest for a 91D...
Kevin Carter July 26th, 2007 09:17 PM
thanks Jeff.
Well these are new batteries, so I don't even know what that means, "left like that for a long time". left like what? But geez, it there a way to know how my battery is doing? I'ts still in warranty.
thanks Adam for that info.
thanks James, what is way to know how you battery life currently is? Is it by how full the battery icon looks after a recharge? or wont a battery always indicate full after a recharge?
"not the LED meter when I mention recharge percent." -- what does that mean?
I guess I'm stuggling how to quantify this easily
Guest July 27th, 2007 06:18 AM
Does anybody have any tips for keeping Li-Ion's life as long as possible, APART from putting it in a cold place? For example, even though they have no memory, should we drain them completely, should we not leave them connected to the charger after they're fully charged etc?
Jeff DeMaagd July 27th, 2007 07:29 AM
Originally Posted by Kevin Carter (Post 719278)
thanks Jeff.
As in it's bad for a Lithium battery to be left dead for months at a time.
New batteries shouldn't have a problem, though I would hope you can exchange them.
