-   Sony HVR-A1 and HDR-HC Series (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/)
-   -   wireless mic with HVR-A1 (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/96466-wireless-mic-hvr-a1.html)
Cindy Konits June 13th, 2007 01:28 PM
Here is another very basic question...I apologize in advance....
I am trying to use a wireless mic instead of the mic that came with the HVR-A1. When I connect it to the XLR port, it doesn't override the internal mic in the camera. What am I missing?
Cindy
Jason Donaldson June 13th, 2007 06:58 PM
The only thing I can think of as an A1 owner myself is that your Active Interface Shoe connector isn't connected properly. I know when I use my wireless (both the mini jack and the XLR jack) they override the internal mics.
Cindy Konits June 20th, 2007 05:06 PM
Jason,
Thank you for your response. I bet you're right....I do have trouble with the Active Interface Shoe. I imagine it would be hard to explain the right way to connect it. I might have to take the camera in to a Sony dealer.
Cindy
Jason Donaldson June 20th, 2007 05:23 PM
If your AIS connector is like mine, and it should be, there is an arrow on the top of it. There is also a beveled edge on the top right hand side of it. The arrow should point toward the front of the camera, and the beveled edge should be top right when looking down at it. It should just slide into the AIS connector on the amera and feel "locked" in once it's connected. Hope this helps
Cindy Konits June 20th, 2007 06:52 PM
Thank you again Jason! I think I've got it. While we're here...I have a few more audio questions... Is it possible to adjust audio levels while recording? It seems to me that it is all automatic. I assume the volume control in the menu is related only to what I hear through the headphones and not actual volume, right? If not, that would be a very odd way to adjust levels...
Cindy
Jason Donaldson June 21st, 2007 08:31 PM
You can adjust the mic input levels while recording by going through the menu...follow these steps:
menu - standard set - xlr set
from here you can adjust both channels 1 and 2. If you set the levels manually, you will notice that back on the main screen, while recording, you will have sound level meters on the LCD screen. These don't display in the "auto" setting.
The only problem with this, is that the A1U's menu is of course a touch screen, and you might find it difficult to do this while recording without camera shake.
Hope this helps
Victor Wilcox June 22nd, 2007 07:42 AM
The XLR set is one of the settings I keep in my PMenu. Shooting weddings, I've had to use it often (no wireless yet) going from vales to screaming organ at recessional. It reduces the number of screen touches as little.
Jason Donaldson June 25th, 2007 08:42 PM
I'm not sure why it took me so long to add xlr to my personal menu, but I just did it...duh
Manuel Guzman July 9th, 2007 03:41 PM
Off topic a bit but which wireless mic did you go with and how do you like it? :)
Jason Donaldson July 9th, 2007 05:28 PM
For now I am still using the stock xlr that came with it. Cash is tight after buying the glidecam, HVL-20DW2 etc etc.
