A1 to Component Adaptor to Intensity?
OK. This may sound a bit convoluted so please bear with me...
Can I output from my Sony A1U via the component outputs to a component to HDMI adapter and run that through a Black Magic intensity card to avoid the problems associated with HD compression and long GOPs? |
You shouldn't need a component to HDMI converter, you won't need it if you spend the extra $100 on the Intensity Pro.
Whether it looks any better is a different question, I haven't seen anyone do a comparison. Assuming that you are recording directly rather than playing it through tape, you would be trading your MPEG2 / long GOP issues with digital to analog to digital conversion losses. I really don't know which is the bigger bogeyman in this case. |
Interesting point. I know the component out from the A1U looks great and doesn't have the artifacting issues, but I don't know anyone who has actually converted back to digital, so I was hopingsomeone might have had some experience with that.
I was unaware that the Intensity Pro has component inputs. Thanks! BTW - Are you still making the shims to help with the bottom loading issue with the A1U? |
Thanks Jeff. I have a feeling I will be sending off for one soon, since I'm getting near the end of my script (I hope).
Also, I found this thread talking about the Intensity using Cineform to keep things more manageable: http://dvinfo.net/conf/showthread.php?t=94079&page=3 So that thread appears to answers the question. Here's a quote from a person who did some rather extensive testing using the Intensity with an HV20: "The difference between NEOHD and NEOHDV at 10 feet away on any size home theater just isn't there, and NEOHDV kills HDV." |
