-   Sony HVR-A1 and HDR-HC Series (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/)
-   -   Can I accidentally record standard video? (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/82360-can-i-accidentally-record-standard-video.html)
Kevin Carter December 22nd, 2006 09:29 PM
I got this camera
HDR-HC3
for HD, of course.
Need to know:
Is there a possiblity one could accidentally record to Standard DV if one puts in a HD tape? thanks
Chris Barcellos December 22nd, 2006 10:25 PM
DV Tape, HDV Tape, HD tape are all the same. All will record DV standard or HDV.
What matters is what your settings on the camera are. I don't know the HC3, but with FX1 a blue light with lettering comes on to denote HDV being set. Settings are in the menu, and I assume similar for the HC#
Chris Harris December 22nd, 2006 10:41 PM
On the HC1, in the upper left-hand corner, it tells you what format you're recording in, which is HDV1080i if you're recording in HDV. It should be similar for the HC3.
Kevin Carter December 23rd, 2006 05:52 PM
thanks Guys, Chris, I'm not a Chris, but I guess that's ok, no?
Yes, it says 1080, that is very cool. I have to say this camera is layed out so much better,than other camcorders I've used, included 3 chips by Canon etc.
Now, what about dubbing?
What is the indicator for that?
Sometimes I may use 2 of these cameras for dubbing regular old tape.
and sometimes for dubbing HD to HD.
I don't want to screw that up and find out later my HD dubs came out standard.
