-   Sony HVR-A1 and HDR-HC Series (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/)
-   -   iLink Cable and the A1U (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/68383-ilink-cable-a1u.html)
Darren Rousar May 29th, 2006 07:32 AM
My cam is due to arrive tomorrow (Tues).
I finally found the A1 manual online and didn't notice a firewire cable (iLink in Sony-speak) listed in the 'supplied items' list.
Does one come with the cam and if not, what kind should I buy?
David Tamés May 29th, 2006 07:46 AM
Originally Posted by Darren Rousar
[...] firewire cable [...] Does one come with the [HVR-A1U] and if not, what kind should I buy?
I did not get a FireWire cable with my HVR-A1U and my manual states explicitly that it's an "optional accessory." The camera has a 4-pin FireWire connector. Depending on what connection your computer has, you'll need a 4-pin to 6-pin FireWire cable (most common) but it's possible you'll need a 4-pin to 4-pin FireWire cable as some laptops use a 4-pin FireWire connector to save space.
Darren Rousar May 29th, 2006 07:59 AM
Thanks David,
After my post I re-read through some of the PDF manual and also noticed the (optional) designation. Then I went to Amazon and found 2 Sony i.Link cables, the 4 to 4 pin and the 4 to 6 pin. Some reviewer there mentioned the 4 to 4 doesn't work for a Mac so I ordered the 4 to 6.
David Tamés May 29th, 2006 12:01 PM
For a Mac PowerBook, Mac Book, MacBook Pro, iBook, iMac, or PowerMac, the 4 to 6 is the right cable, all the recent Macs (so far) have 6 pin FireWire 400 connectors (the two extra pins provide power to peripherals like smaller hard drives).
