-   Sony HVR-A1 and HDR-HC Series (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/)
-   -   24p hc1 footage (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/54613-24p-hc1-footage.html)
Thierry H. Fortier May 18th, 2006 11:21 AM
Konichiwa, Kaku Ito-san!
sumimassen... I got a question; The first shot of the biker named "Original"... it is from the same camera as the 2 next one with the same motion? because, the original is in 24fps and have a nice motion feel but the 2 others (Fuji and Kodak setting) feel like you have convert it from 60i... the motion is a lot less smooth and you can see overlapping frames...
If the first one is from HC1 with 24p conversion (magic bullet or Fields kit) its really really a good job... but then I wonder why the 2 others dont have the same smooth feelling...
I ask that cause I was planning to shoot in PAL 50i (rented Z1u) for avoid stuttering 24p conversion... but if you get good result as the first shot, I will not bother and buy a hc1 ntcs right away!
thanks!
Thierry H. Fortier May 18th, 2006 01:13 PM
oooops... or maybe I should ask Jung!
Forrest Schultz May 18th, 2006 08:39 PM
Jung never posts here after his initial posts. dont count on an answer.
Alex Thames May 18th, 2006 08:49 PM
Yeah, the way I see it, there's no point to these types of threads if he doesn't care to share how.
Thierry H. Fortier May 18th, 2006 09:13 PM
a mysterious man!
from Jung second post, I can read the first clip is really from the hc1... hard to believe, there is no stutter at all at 24p... but why then not simply use that one and color correct... I dont understand why stutter appear in the 2 other clip...
