-   Sony HVR-A1 and HDR-HC Series (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/)
-   -   Sony HDR-HC9 AV- in ? (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/522582-sony-hdr-hc9-av.html)
erik luneberg April 4th, 2014 03:59 AM
Hi
I have this Sony cam, but it seems there is NO av- in on this cam.
Is there a work around maybe?
I remembered years ago that i was able to change the HEX, on windows 95 with a special cable ( still have that cable) and also the windows 95 PC.
But...i am a little scared to try it on this cam.
Maybe someone has suggestions?
Make my own cable perhaps?
There is a Sony lanc on this cam.
Regards
Erik
J. Stephen McDonald March 17th, 2015 08:53 PM
Re: Sony HDR-HC9 AV- in ?
It's been so long since I used my HC9, that I've forgotten exactly how to do an AV input, but I know it can be done. You probably have to use the special, multi-headed cable that came with it.
Adam Gold March 17th, 2015 11:12 PM
Pretty sure the only input possible is via iLink. Everything else is out only, IIRC. Page 85.
erik luneberg March 20th, 2015 04:08 AM
Thank you
I will try that.
I still like using tape because of the Bumps with ski slopes.
I have sevaral digital cams, but ...
Cheers
Erik
Amst-europe
Jack Zhang March 20th, 2015 10:17 AM
My HC7 has no analog in. You're going to have to get a Canopus/Grass Valley ADVC, then plug that into the i.link port on the HC9.
Old Canon camcorders also had AV->DV function built in.
erik luneberg March 20th, 2015 10:50 AM
How do i power it up
i have a backpack with the sony in it.
Is there some smaller device solution ???
erik luneberg March 22nd, 2015 01:23 PM
Forgot to ask:
If the converter is needed to get analoge to digital signal, then i also can use a digital signal directly in to the Sony ??
That would be great
However i cannot find any info on it and neighter any cable.
Regards
Thnx for all comments
